Sony AX5000 Issue / Question
Old Oct 7, 2018 | 09:19 AM
Fullbore55's Avatar
Fullbore55
Originally Posted by SgtMic
I ran mine for a few days last week and didn't have the shutting down issue. Only issue I had was Android Auto wanting me to set the parking brake.
Don't have one of those so I'm assuming it;s either miswired or I need to update the firmware.
Is this issue new or did it always prompt for parking brake? If new, I don’t know cause, otherwise should be able to simply ground that wire.
Old Oct 7, 2018 | 10:57 AM
SgtMic's Avatar
SgtMic
It started as soon as I installed the app for the first time. Yes, I need to ground the parking brake wire when I get my bike back from the dyno tuner.
Old Oct 7, 2018 | 06:59 PM
skibum0607's Avatar
skibum0607
Yeah, it's wired wrong. I bought mine with a custom harness and they sell a different harness if you're using Android Auto vs Apple Carplay. If you're not able to figure it out you might call the guys at Fat Head Cycle and get one of their custom harnesses for Android Auto.
Old Oct 7, 2018 | 08:23 PM
SgtMic's Avatar
SgtMic
I bought mine from volunteer audio off Ebay. Supposed to be plug and play.
Old Oct 7, 2018 | 09:33 PM
Fullbore55's Avatar
Fullbore55
I got mine, along with amp, from 702 Motoring in Vegas. I think the Sony, bezel, and adapter harness was same as from volunteer. When you have time to open the fairing, check the “parking” wire.
Old Oct 7, 2018 | 10:14 PM
Ryan42's Avatar
Ryan42
In regards to this Radio how can you then turn off or turn on your eitms? What about oil pressure and air temp?
Old Oct 7, 2018 | 10:49 PM
Fullbore55's Avatar
Fullbore55
Good q about eitums. I guess I leave mine on, can always blip throttle it it bugs me. Temp and oil are both worthless IMO.
Old Oct 7, 2018 | 11:03 PM
Ryan42's Avatar
Ryan42
why is oil pressure worthless?
Old Oct 8, 2018 | 06:20 AM
SgtMic's Avatar
SgtMic
I can use my PV to turn eitms on or off. Never checked oil pressure or temp too much so I won't miss those.
Old Oct 9, 2018 | 11:05 AM
MMXIWG's Avatar
MMXIWG
You can roll the throttle forward and watch the cruise control light. It blinks when Eitms is turned on or off I believe. It’s in the owners manual how to do it.
