Bluetooth connection constantly drops while riding.
Old Dec 21, 2018 | 07:35 AM
barneyboy's Avatar
barneyboy
Originally Posted by cruzomatic
It's doing a lot more than pausing bro, it cuts in and out constantly. I found the icon symbol in "Boom Box owner's manual" it's described as, "media paused" "media is paused, press POWER/MUTE switch to resume audio.
I currently have the battery disconnected, maybe that's do a reset of the whole system of sorts.
Disconnecting the battery does not reset the radio. If you want to reset the radio, perform the procedure below.
Old Dec 22, 2018 | 04:09 AM
cruzomatic's Avatar
cruzomatic
Hey Barney, nice, thanks for posting that, appreciate it. I'll give it a try.
Old Dec 23, 2018 | 08:42 AM
cruzomatic's Avatar
cruzomatic
I reset the radio last night, hopefully that helps it. Haven't had a chance to take a test ride.
Old Dec 23, 2018 | 09:58 AM
barneyboy's Avatar
barneyboy
Keep in mind that the radio has been reset to factory defaults. Any settings previously selected will need to be reselected, including pairing your device.
Old Dec 23, 2018 | 06:51 PM
cruzomatic's Avatar
cruzomatic
Yes Sir....thanks for your help Barney. I hope that was the problem.
Old Jan 12, 2019 | 11:14 AM
cruzomatic's Avatar
cruzomatic
Update:
I reset the whole system as per Barney's instructions listed above and that did the trick. It's working just as it should now!
Thanks all for chiming in.
Old Jan 13, 2019 | 11:09 AM
barneyboy's Avatar
barneyboy
Update:
That's good to hear. Check your software for the latest version (1.22.0.1). I also have a 2018 FLHXS that was manufactured 9/17. I had to update mine from the previous version.
Old Jan 14, 2019 | 06:44 PM
cruzomatic's Avatar
cruzomatic
Will do Barney, thanks. Appreciate it.
Old Jan 15, 2019 | 05:02 PM
Srodden's Avatar
Srodden
Originally Posted by Rocket67
When mine is out of reach it does not pause, it switches to the radio. Mine does get spotty sometimes when my phone is in the tourpak, never happens when in the windshield bag. Range is not great on the Bluetooth.
exactly ! When your body is between the phone and boom radio it causes issues.
Old Apr 13, 2023 | 01:40 PM
Jayz455's Avatar
Jayz455
Stage I
If you’ve had a flash done to your radio would that delete the flash? Thanks
