Help understanding Time Alignment
Old Feb 11, 2019 | 10:06 AM
Mike14SG's Avatar
Mike14SG
Default Help understanding Time Alignment
For the Masters of all things audio ... Can someone please help me to understand the best way to do the time alignment and how it changes during riding? I realize that this is next level skills but I am trying to make my sled sound as good as I can with the tools available. Thanks in advance
Old Feb 11, 2019 | 10:45 AM
Babyboy's Avatar
Babyboy
You can get all technical when setting time alignment but with us in the open environment most of the time alignment will go away when you start moving.
The best way to go about setting your time alignment is set it in a parking lot pimp mode.
If you have the abilities to switch your DSP settings once you have the engine running and rolling down the road you can reset the time alignment for moving.
The only bad thing is your time alignment settings are going to always be fluctuating when you are rolling down the road in an open environment. As your speed changes the lower frequencies will get farther behind you as the wave lengths are longer and farther apart then the higher frequencies.
Clear as southern muddy water right??
Old Feb 11, 2019 | 11:10 AM
Mike14SG's Avatar
Mike14SG
Yep as clear as swamp mud but pretty much what I was thinking so I will just set my PLPM and not worry too much about time alignment on my riding set which is where I spend most of my time anyway
Old Feb 11, 2019 | 11:34 AM
Sparky357's Avatar
Sparky357
Time Align is more critical in a car rather than a bike because on a bike the two speakers are pretty much equal distance from your ears. In a car th he speakers are all at different distances affecting soundstage.
Old Feb 11, 2019 | 05:48 PM
SOFTPETER's Avatar
SOFTPETER
You are correct.
Hoyt 1911A1
Audio Systems
Sep 29, 2018 04:08 PM
Joeymcg
Audio Systems
May 20, 2018 09:21 AM
TexasD
Audio Systems
May 7, 2018 11:48 PM
redliner996
Audio Systems
Mar 3, 2018 10:44 AM
jimfount00
Audio Systems
Sep 12, 2015 03:30 PM
