That being the case it looks like you will need six amplified channels to balance everything out. To keep FM I don't know how you could do that for under a grand. I think Bates had a setup similar to what you are looking to do at one time. Maybe he can give you some recommendations for your budget.
There are many ways it could be done for less than a grand and sound good. One extremely low budget option would be:
1 Soundstream PN4 1000d amp $130.
4 Timpiano 6.5 slims speakers for lowers and rear pods $120. (loud and good lows but harsh on the highs, which can be tuned out with the DSP)
1 Dayton Audio DSP $180 w/bluetooth. or Rockford Fosgate DSR1 $250.
that leaves $500. - $570. for a good set of fairing speaks plus wiring, RCA's etc.
Run the 4 Timpiano's parallel on the rear channels and the fairing speaks on the fronts.
If he doesn't mind losing FM then sure he could do it for under a grand.
would like to be able to hear my rear speakers myself
Also you are recommending he parallel the lowers and rear pods which will prevent him from being able to control the volume of the pods independently: That was the reason I recommended six channels somehow. Again the price is based on him giving up something he said he wanted. If he is willing to give that up then fine, but I went down that road myself using similar components and quickly realized the limitations of the setup.
Wow this is turning out to be a little more complicated then I thought it would be.
Hang in there man. Dont get discouraged some of us get carried away with what your asking
on here and forget to explain it to you instead of having a conversation with each other. A lot is just
wiring and not hard to do just keep asking your questions.
Alton If you want to start out simple and see how you like it you could just follow everything Ndfastin listed minus the DSP and see how you like it. The DSP is nice but it can be overwhelming for folks starting out. You will lose a bit of FM reception but if you live in or near a city you still may pick up enough to get you by. The one sticking point with that build may be that you when you balance the fairing speakers and lowers to blend well you probably won't hear the rear pod speakers much. You will get so much sound from the front stage due to the addition of the lowers that you may not miss the pods that much.
Another option could be to put the four front speakers on the fairing amp one per channel and have that amp on the front two outputs of your head unit (you could balance out the fairing and lowers by putting a cheap RCA level control on the faring channel) and get a smaller micro amp to power the rear pods and feed it with the rear preamp outputs of your head unit. That is sort of what I have now. I can fade between the front speakers and rears at will with the thumb fader control.
A couple weeks ago I went to a swap meet/clearance sale at the local Harley dealer and I picked up a brand new hogtunes 7 fairing lower speaker kit. Model fl-7w. I got them for $100 figured why not thats more then half off. Would they be a decent speaker for my lowers ? I know I need an amp to push them.
hogtunes 7” fairing lower speaker kit. Model fl-7w
I have never heard them but one of the pros here said he had and they didn't sound too good. You could use them to get started but they would most likely need to be on their own amp channel because they are 2 ohms according to a picture on the website. Those are one of those mass market "kits" that don't usually list a lot of the technical details.
Most here would tell you to pass on them I'm pretty sure. If you are strapped for cash though I understand.
So I think Ive decided that for now Im going to focus on the fairing and lower fairing speakers. So from what I understand Im going to need one 4 channel amp to run those four speakers . So basically I need to figure out what speakers to get and what kind of amp. Id like to keep the fm radio if at all possible. So Im assuming Im going to need an expensive amp to cut back on the interference. Someone had suggested Rockford fosgate amp And speakers....any thoughts?
Given that you have a hu and $1000 budget and a hope to retain fm
id look for opinions on the sound digital 800.4 amp, Hertz HCX 165 in the fairing and hertz sv165 in the lowers.
from most of my reading here all those pieces get very good reviews and would give you a very good system start.
the waters are getting muddy here but if you listen to the likes of bates, travelingypse, tailwind etc. (The ones that know what they are talking about is obvious). They’ll steer you right.
