Waterproofing membrane?
Old Mar 2, 2019 | 07:13 PM
Alphadog4312's Avatar
Alphadog4312
Default Waterproofing membrane?
I can not recall who turned me on to this product in a past post? I believe it was Gypse. I would like to know what anyone else has done for application? I’m thinking 3M adhesive spray? Also how did anyone get the creases out of the material? Thanks!
Old Mar 4, 2019 | 10:05 AM
mikes300's Avatar
mikes300
I ironed out the wrinkles,and it did not seem to affect its water resistance. i jut cut mine to fit the grills on the front and glued them in, on the rear a little glue and then sandwiched it
in between the lid and cone.
Old Mar 4, 2019 | 11:12 AM
Alphadog4312
Thanks Mike
I was thinking the same thing as far as the iron but did not try it, mostly because I’m not sure where the Mrs. keeps it. I used a heat gun and got them pretty smooth. I will say don’t get distracted or it will distort quickly even on a low heat setting.
Old Mar 5, 2019 | 09:20 AM
Respect's Avatar
Respect
Silicone will shrink when it dries and that tends to pull it taut. Lay a thin bead and watch the magic happen. I use frogskin.
Old Jun 20, 2019 | 07:07 PM
bladeguy's Avatar
bladeguy
How did you do this? I tried it and was moving all over the place what is a complete mess
Old Jun 21, 2019 | 12:41 PM
Alphadog4312
I did not use silicone. I placed the membrane inside the grill using a light coat of Scotch 77(?) spray adhesive. Only had two holes close up, hardly noticeable.
Schreff
Jul 12, 2011 05:55 PM
SeanS
Nov 26, 2007 05:54 PM
