Beginners ProAudio Set-up
Old Mar 25, 2019 | 10:09 PM
slodsm's Avatar
slodsm
MR500's have made me very happy as midrange speakers. They are LOUD and very clear with 200w going to each of them. I've never used PRV tweeters or 10's so I can't comment on them but a 10/8 will be required with the mr500's as they aren't a speaker that will play low and loud at the same time (for me at least) but they are amazing at vocals and up to 10k hz.
I do use a DSR1 as well and I'm very happy with it but it's by first DSP in a very long time so I don't know how to compare it to the plethora of other options out there.
For amps I'm using SD stuff because I love the power for the size.
Haze won't steer you wrong.
Old Mar 26, 2019 | 01:50 PM
Harley SSG's Avatar
Harley SSG
Thanks for the input on the MR500. I ordered them and should have them in 1-2 days. What SD amp should I go with? I still have my RF400 from a previous build, and plan to use this in addition to any other amp.
Old Mar 26, 2019 | 02:06 PM
Tailwind's Avatar
Tailwind
Why have you selected the SD amp line?
T
Old Mar 27, 2019 | 06:56 AM
Harley SSG's Avatar
Harley SSG
I’m new to PA. Right now I’m taking recommendations and weighing options. If not SD, what would u recommend?
Old Mar 27, 2019 | 07:22 AM
travelingypsye's Avatar
travelingypsye
I personally am not a fan of the currant SD amps. They are loud as hell but for my old ears, the SQ from them just isn't the same as a JL, stinger or even a tm400 amp. As Haze stated, the t400 will work but they are $$ for what you get. I ran one for a long time and still have it on the shelf just incase but I replaced it with a stinger and couldn't be happier. I did try a SD 1200.4 evo but just couldn't get it to sound as good as the stinger. I am sure with a dsp, the SD amp can be tuned to sound good.
Old Mar 27, 2019 | 08:09 AM
Tailwind's Avatar
Tailwind
Not at all saying SD is not a very solid choice. Just curious why you ask what SD amp you should get. Lots of choices out there and some other brands may fit your specific build a bit better.
T
Old Mar 28, 2019 | 04:35 PM
Harley SSG's Avatar
Harley SSG
I currently have TM400 from a previous build, so the shop suggested I stick w/ RF. Someone mentioned SD, so I was curious what would go well with my build.
T
FrenchieM
Audio Systems
Jul 10, 2019 09:44 PM
Keshunjohnson
Audio Systems
Jan 10, 2019 10:14 AM
tundrabuilt
Audio Systems
Jun 5, 2017 07:14 AM
brent1024
Audio Systems
15
Dec 31, 2014 01:19 PM
StreetGlider57
Nov 28, 2008 01:36 PM
