Need speaker help - FXRP fairing
i have a soare diamond audio micro4v2 amp with the Bluetooth controller. I’d like to wire up 2 speakers but not sure which way I should go? I’m by no means an expert, I just know which wire goes where lol.
Ill be installing the amp on a 2011 FLHR with a RWD FXRP fairing. No cutouts. I don’t think I can go bigger than 5.5” speakers.
What would you you guys recommend? Which ohm rating would be best ?
Here are the amp specs
- RMS Power Rating
- RMS Power (2Ω): 150W x 4
- RMS Power (4Ω): 80W x 4
- Bridged (mono 1Ω): N/A
- Bridged (mono 2Ω): N/A
- Bridged (mono 4Ω): 300W x 2
- Type
- Topology: Full Range Class D
- Power Supply
- Power Supply: Full PWM
- Power Supply Threshold: 10.0VDC - 17.0VDC
- Idle Current: (0.7A)
- Distortion
- THD 4 (1KHx @ 4Ω): 0.5%
- S/N Ratio (A weighted @1W): -85dBA
- S/N Ratio (A weighted @FP): -101.1dBA
- Input Sensitivity
- Low Input Level: 200mV - 10.0V
- High Input Level: N/A
- Input Impedance
- Low Input Level: 20KΩ
- High Input Level: 20KΩ
- Output Stage
- Output Impedance: 0.018Ω
- Damping Factor (50Hz@4Ω): >70
- Bandwidth (-3dB): 10Hz - 35Hz
- Crossover (-12dB/Oct)
- Variable High-Pass: 40Hz - 400Hz
- Variable Low-Pass: 40Hz - 400Hz
- Variable Sun-Sonic: N/A
- Fuse Ratings
- ATC: 40A
- Dimensions
- Length x Width x Height (Inches): 9.07 x 4.0 x 1.46
- Length x Width x Height (mm): 230.5 x 103 x 37.2
m
https://prvaudio.com/products/5mr450-ndy-4/
http://www.usspeaker.com/beyma%205cx200nd-1.htm (may need the recommended crossover or DSP)
http://www.usspeaker.com/beyma%205g40nd-1.htm
