4 speaker set up
Old Apr 3, 2019 | 01:12 PM
travelingypsye's Avatar
travelingypsye
I would set the crossover around 80 and let them break in then run the hell out of them. if it were other 6x9's you may not have enough power for 4 6x9's but those mmats don't need a ton of power to get loud. I would also suggest just trying them in the lids first before taking up bag space for another set. The reason I say that is I am not convinced that anything in the bags facing the rear wheel can be heard with any significant SQ at speed anyway. That is just my opinion though.
Old Apr 3, 2019 | 03:03 PM
Tailwind's Avatar
Tailwind
Originally Posted by Rckoutwurcokout
Sry I didn’t mean bridged. I meant amp switched to 2 ohm. So 4 mmats 690 in rear running parallel off of channel 3+4 and Focal krx2k2 off of channel 1+2. With the focal fdp sport switched to 2 ohm. What do you set the crossover too for the Mmats
R u talking about the Mmats PS69cx coax for the Mmats 6x9 midrange?
T
Old Apr 3, 2019 | 03:58 PM
Rckoutwurcokout's Avatar
Rckoutwurcokout
Mmats mids
Old Apr 3, 2019 | 04:00 PM
Rckoutwurcokout
Open to suggestions though. Thinking 2 in bags n 2 in lids
Old Apr 3, 2019 | 04:26 PM
Tailwind's Avatar
Tailwind
Go with the coax in the lids if it's in ur budget.
T
Old Apr 3, 2019 | 06:27 PM
Rckoutwurcokout
Looks like those r the way to go. How would 4 of them work on 2 channels of the focal fdp sport with my focal k2 components on the other 2. Amp switched on 2 ohm I assume. K2’s are 2 ohm
Old Apr 3, 2019 | 06:30 PM
Rckoutwurcokout
Plus what is the sensitivity on those
Old Apr 3, 2019 | 09:27 PM
Babyboy's Avatar
Babyboy
Research research as the rest of have done in the past and still do to at the present time.
Someone coming to a forum asking for specs on a speaker is as easy as going on the interweb and looking up said speaker in question to get the answers.
The answers are only a few key stocks away
Old Apr 3, 2019 | 10:48 PM
Tailwind's Avatar
Tailwind
It's actually a pretty legit question. Mmats is one of those companies that has very substandard product specs that are far from readily available. And their catalog is from 2017!!!!
T
Old Apr 3, 2019 | 11:09 PM
Rckoutwurcokout
Thanks t. As long as u think they will slam n r loud that’s all I need. Does the setup I posted look good
3rdEyeStreetGlider
Audio Systems
Sep 15, 2018 10:28 AM
65049
Audio Systems
Nov 13, 2016 01:47 AM
GLYDN
Audio Systems
Sep 26, 2016 12:10 PM
Jetblack3
Audio Systems
Mar 15, 2014 12:18 PM
badazzpred
Audio Systems
26
Jun 14, 2013 07:22 AM
