Saddlebag 6x9 setup
Old Apr 4, 2019 | 09:16 PM
Rckoutwurcokout's Avatar
Rckoutwurcokout
Default Saddlebag 6x9 setup
So I’m adding saddlebag lid speakers for sure but not sure if I want to add two inside the bags. Kenwood head unit, focal fdp sport, focal krx2 2 ohm components up front and T talked me into the mmats ps69cx 6x9 for rear. My question is should I run one set of 6 x 9’s just in the lids and run the system at four ohms or add a second set inside the bags and run the system at two ohms. what are advantages disadvantages. Sound, heat, power consumption etc. Looking for the best possible way to set the system up. Thank you guys so much for your help I really appreciated it in my last post😀
Old Apr 4, 2019 | 09:20 PM
marcodarq's Avatar
marcodarq
i'd start with the Mmats in the lids and see how you like it, if it's enough (NEVER), put a pair of DD VO6x9s or a pair of 8s inside.
m
Old Apr 4, 2019 | 09:27 PM
Rckoutwurcokout
You’re right it never is enough that’s why am thinking about adding four of the same mmats on the rear two Channels so I can bridge them and run my whole system at two ohms off that amp. 250x4 at 2 ohm amp
Old Apr 4, 2019 | 10:40 PM
Tailwind's Avatar
Tailwind
Totally agree w Marco. Run the lids then let ur ears decide what the next step is.
I gonna guess that a micro amp mounted under the hood tied to some 8s inside the bag might be ur next step.
T
Old Apr 5, 2019 | 12:19 AM
Rckoutwurcokout
[QUOTE=Tailwind;18159408]Totally agree w Marco. Run the lids then let ur ears decide what the next step is.
How much power do those mmats ps69cx’s like
ReDo
Audio Systems
57
Sep 14, 2018 10:05 PM
USCG Chief
Audio Systems
Nov 29, 2015 04:23 AM
Cool Poppa
Audio Systems
Jul 1, 2015 05:59 PM
barkingspud
Audio Systems
May 18, 2013 09:50 PM
PistonPuller
Mar 26, 2012 09:20 PM
