Question fellas
Old Apr 6, 2019 | 05:17 PM
big- mike's Avatar
big- mike
Default Question fellas
Just over a year ago I upgraded to 4 mm1 polka and a rz4-1000d amp , love the system worked great all last year. Today I went for my first good ride of the season 10 minutes into the ride I lost sound out of the right front speaker only finished my ride expecting to take it all apart looking for a loose wire or something. When I got home I shut the bike off and then turned it back in and the right front started working again. Not sure what to look for at this point. Any suggestions would be appreciated
Old Apr 6, 2019 | 05:50 PM
2017M8's Avatar
2017M8
Just like a computer sometimes you have to reset um'',,,,,,,,kidding,,,,,,,,,,,,, It maybe follow your footsteps and try to get it act up,,, let it it run for a few minutes with some volume and let it heat up ,,,,seee if it cycles again,,,,,,
Old Apr 6, 2019 | 05:53 PM
big- mike's Avatar
big- mike
I didn’t know if there were relays in the amp that maybe dropped out.
Old Apr 7, 2019 | 05:21 AM
Dsm Limited's Avatar
Dsm Limited
Im not familiar with that particular amp, but some amplifiers will go into protect mode. If no adjustments were made between last season and this one, I'd be looking for an intermittent connection. Check speaker output at amp and speaker, also check the rca connection between head unit and amp.
Old Apr 7, 2019 | 09:27 AM
big- mike's Avatar
big- mike
Ok so basically go back in and check all the connections
Old Apr 7, 2019 | 12:48 PM
Fireball Jack's Avatar
Fireball Jack
I have the SS PN$.1000d and i lose the left front about every two months, Two things fix it temp. 1 turning up the volume and it comes back. 2 taking the Fairing off and cycling the LP Flat HP filter selector. The 2nd seems to work for a couple of months or so., 1 seems to fix it very temp.
Old Apr 7, 2019 | 03:43 PM
big- mike's Avatar
big- mike
Rode it again today for about an hour and it stayed on so maybe turning it off the back on resets something. If it happens again I’ll open it up and check all the connections but I would rather not under that fairing is like putting ten pounds of crap in a five pound bag.
Old Apr 7, 2019 | 04:24 PM
Fireball Jack
if it happens again try turning up the volume. I chased this for a while before I found the bad switch connection.
Old Apr 7, 2019 | 05:12 PM
big- mike's Avatar
big- mike
Thanks I’ll try that
Jsnake
Audio Systems
Jul 22, 2016 08:02 PM
Tailwind
Audio Systems
May 2, 2016 09:14 PM
Tailwind
Audio Systems
16
Feb 5, 2016 02:38 PM
Sandhog
Audio Systems
Jun 6, 2015 08:10 AM
rodman4196
Mar 23, 2011 11:09 PM
