I appreciate it, but I am 5 months sober after dealing with PTSD. This bike was my chance to get my mind off other things, and rework my brain. I'm not a mechanical guy by nature. I'm a Marine and a Cop, but ****ing up mechanical stuff is surprising therapudic...At least once you figure it out.
More therapeutic than most thing is taking on a project that you know squat about and finally having an "accomplished moment" when it is done.
You and I are in the exact same boat man. Thats why I tear everything I own apart constantly and make it better. Keeps my hands and mind occupied which makes life better by far.
That said, at least you forgot to hook yours up. A few months ago I forgot to take mine off and broke that **** right st the fitting pulling the tank up haha.
Today, I'm riding into work, and all the sudden Android Auto shoots and error and goes off. Then I try to switch to Bluetooth audio, and it only wants to connect to call audio, not music. It sounded good for the short time it worked.
Thanks for your service,I almost did what you did i put mine back together came in the house and about an hr.later thought of the fuel line.As for the battery after install tuning put the trickle charger on took hrs.for it to charge.It will drain a battery quick.Had back surgery first thing i've done helps to stay busy.
