Cooling Amp with a fan
Old May 21, 2019 | 11:05 AM
kdogg77's Avatar
kdogg77
4th Gear
Default Cooling Amp with a fan
Was wondering if anybody installed cooling fans on top or near there amps to help keep them cooler on long rides on a hot day. Going on a 7 hour ride soon and want to make sure my amps aren't over heating during trip. I have a 800.4 sd and 400.4 sd .
Old May 22, 2019 | 09:06 AM
marshallb's Avatar
marshallb
Where are they located?
Old May 22, 2019 | 09:07 AM
kdogg77's Avatar
kdogg77
4th Gear
Tour pack
Old May 22, 2019 | 09:12 AM
marshallb's Avatar
marshallb
I don't think you'll have an issue. I ride about 5 hrs Sunday with an amp in my saddlebag with a pretty demanding load and did have any trouble.
Old May 22, 2019 | 09:30 AM
cprhed's Avatar
cprhed
I have done it.
The amps usually have vents on the ends to let air in. I have only had to do it twice but both went well.
I picked up a small slow speed computer fan from Radio Shack. Cut a hole in the top cover of the amp that match the fan opening. Attached the fan over the hole and wired it up with remote so it only came on with the amp. I mounted it so that it drew air up and out rather than forcing it in. That way it pulled cool air in from the ends across the board and up out of the top. In both cases the amp would heat up and click off on a long trip. Following the fan install neither ever heated up again.
Old May 22, 2019 | 11:56 AM
kdogg77's Avatar
kdogg77
4th Gear
I really appreciate the input because I done want my amps cutting out on me on a 7 hour ride. Going to order me some fans and see ihow ts goes. Thanks
Old May 22, 2019 | 12:58 PM
cprhed's Avatar
cprhed
It doesn't take much. Dont need to be like car AC on full blast. Just something to move air
Timberjkd
Audio Systems
15
Jul 20, 2019 05:41 PM
EdsRoadGlide2017
Audio Systems
Jul 20, 2017 02:53 PM
Moto Mike
Audio Systems
May 16, 2017 08:37 PM
bgismo20
Apr 16, 2008 03:05 PM
