Delete lids for lowers?
Old Jul 6, 2019 | 01:27 PM
laman22's Avatar
laman22
Default Delete lids for lowers?
14 Limited Sony xav 5000 in fairing have Hertz mpk domes are on nano 250- speakers are on SD 800.4 the other channels feed Hertz mpx in T.P. have sd 400.4 In bags feeding Hertz mpx 6X9 im looking for more thinking of trying lowers and deleting lids and feed them from the 400.4 as i have no more dsr-1 outputs I really don't hear the lids over 30 what your thought and input for a speaker that fit the hogtune liquid lowers I realize I will have to retune also I bridge the 400.4 and get like 244 watts
Old Jul 6, 2019 | 01:39 PM
marcodarq's Avatar
marcodarq
if you made a 1/4 or 3/8's inch spacer to go under the speaker, you might be able to get a Mmmats PA 601 or a hertz sv165 in the hole. how it would look and what kind of grill set up would work i don't know, but i'm spitballing here. once you have a good speaker in the hole, get rid of the 400.4 and get another 800.4, use it to drive your lowers and lids, tune it and good to go. horns on 1&2, fairings on 3&4, lowers on 5&6 and lids on 7&8.
tune it and go, to me, lowers are a worthwhile investment and you will here them all the time if you plan it out well.
m
Old Jul 6, 2019 | 04:01 PM
laman22's Avatar
laman22
Default Idk
I have 1-2 on horns 3-4 on fairing 5-6 on. Tour pack 7-8 lids no
more room to tune also I have 400.4 bridged like 244 watts and I have hard time hearing them also hertz sv take a lot power them and 800.4 at 125 I don’t think would cut it
Old Jul 6, 2019 | 05:06 PM
marcodarq's Avatar
marcodarq
take horns/tweeters off 1and 2 and run straight of the nano, head unit speaker out put, that will give you 2 more, you are mistaken about what those speakers need and what is enough to run them. the power from a SDEvo800.4 is plenty for both your 6x9s and your 6.5s. another option would to be putting the tp's and lowers in parallel, this works ok sometimes because both the tp pod and the lower pod have kinda small airspaces to work with. The Evo 800 puts out 144 watts, maybe some more, so i have a hard time thinking it's not enough, especially after testing it on your same speakers.
you could also ditch the dsr1 and get the DD dsi2, which would give you ten outs, use the 2 outs that have are just through outs to send signal to your tweeters. just ideas for you
.m
if you need more power get the Evo1200.4 and put it in a bag.
Old Jul 6, 2019 | 05:37 PM
laman22's Avatar
laman22
I’d hate to do that to the horn then I would have to put the crossovers in / maybe my 6x9 are messed up I got 400.4 bridged that’s over 200 watts plus and my MPK in fairing is twice as loud
Old Jul 6, 2019 | 06:03 PM
laman22's Avatar
laman22
Also if I replace 400.4 with 800.4 to run lids and lowers in channel 7-8 on dsr how in the hell am I gonna tune it with 2 way different style speakers makes no cents
Old Jul 6, 2019 | 06:51 PM
marcodarq's Avatar
marcodarq
Lowers and tp pods in parallel on 2 channels, they will tune very similar, lids on their own 2 channels and tuned individually.
M
Old Jul 6, 2019 | 07:05 PM
laman22's Avatar
laman22
T.P. Are in 800.4 in fairing with the MPK and T.P. Are mpx/ lowers would be hertz sv not enough power to run lowers and T.P. Parrell sv need at juice
Old Jul 6, 2019 | 07:30 PM
Juice's Avatar
Juice
Deleted.
rblahetka
Audio Systems
19
Dec 9, 2017 10:31 PM
cash64
Audio Systems
14
Sep 23, 2016 03:28 PM
05hdultra
Audio Systems
Mar 29, 2015 07:42 AM
crankee
Audio Systems
Mar 31, 2014 11:13 AM
kryingame
Jan 30, 2014 09:20 AM
