Best 4 speaker set up
Old Jul 11, 2019 | 02:02 PM
wevsspot's Avatar
wevsspot
Originally Posted by mrmagloo
This is a great reco for the RG!!! Just wondering how would you adjust this for an Ultra with the Batwing? I'm not sure that DA will fit under the hood with the SD, will it? TIA!
If you can get the SD under the radio, you can mount the DA MIcro4v2 on top of the headlight. Not sure where to squeeze a DD DSI1 after that though. The ARC PSM would probably fit somewhere.
Old Jul 11, 2019 | 05:48 PM
HDK's Avatar
HDK
Originally Posted by wevsspot
Where both of those installs on Road Glides? If not, there isn't really an apples to apples comparison.
One was is a road glide and the other is an ultra limited. Both sound awesome. Their set ups were Arc amps and
Focal EC 165K speakers. Both are 4 speaker set ups.
Old Jul 11, 2019 | 06:02 PM
HDK's Avatar
HDK
Originally Posted by haze324
If you are talking about BEST set up with no budget concerns. I'd go with:
Fairing Beyma 6CX200Nd
Lowers Beyma 6GMnd
Amp SD 800.4 to the Fairing speakers
Diamond Audio micro4 (it fits) to the lowers
Sony Radio
Arc PSM or DD DSI1 as the DSP.
Let it rip.
I actually have another SD800.4 . Would that be suitable replacement for this set up to run the speakers in the lowers if amp was placed in one of the bags? Also have a rockford dsr1. Would that work instead of the other DSP or are the others that much better?
Old Jul 11, 2019 | 06:06 PM
HDK's Avatar
HDK
Considering the platform, I think your problem is power and tuning. At best case your SOUNDIGITAL SD800.4D EVO 4 is only capable of outputting 110W to 144W per channel driving a 4 Ohm load pushed to four channels. I don't really think there is an issue with your current speakers. The HCX 165 are proven performers built like a tank and can easily handle more power than you're giving them. Same thing for the MMATS. Loud is an interesting term that gets used a lot when discussing bike audio. But it really boils down to about five things;
Wattage coming from the AMP
Power handling capability of the speakers
Sensitivity rating of the speakers
How much clean power can you feed the speakers before they start to distort
How many speakers you're running
I commonly recommend to people that they target 150W minimum per channel on a Shark Nose, and 175W to 225W or more is even better.
If you want "louder" figure out a solution for driving more clean watts to your current speakers. Tweak your tune, and then go from there.
I actually already have another SD 800.4 amp. Would one running fairing speakers and the other running lowers out of a saddlebag be a better option than what I am running now. Both sets still controlled through dsr1 as well?
Old Jul 11, 2019 | 06:54 PM
InthewindMN's Avatar
InthewindMN
One sd800.4 2ohm wired bridge/parallel will give all 4 200w each.
Old Jul 11, 2019 | 08:24 PM
SBates08's Avatar
SBates08
Which is more than enough for those speakers.
Old Jul 11, 2019 | 10:39 PM
09baggerdude's Avatar
09baggerdude
True. But then how can you tune them seperately?
Old Jul 11, 2019 | 10:45 PM
Tailwind's Avatar
Tailwind
You don't parallel left and right, you parallel stages ie fairing on channel 1/2 w cross / gain set accordingly and lowers on 3/4 w cross and gain set accordingly.
T
Old Jul 12, 2019 | 02:15 PM
decencyxdefied's Avatar
decencyxdefied
Ive kinda been saving up for new gear. Now my budget needs to increase so i can afford the below mentioned crap
Lowers Beyma 6GMnd
Sony Radio
Let it rip.
Old Jul 12, 2019 | 03:26 PM
HDK's Avatar
HDK
Me too. Gonna hold off on the merry go round for a bit and wait til I can go with something like this. I loaded tune sent to me last night for the dsr1 and it improved it quite a bit. Gonna tune the amp a bit tonight and see if I can get a little more out of it. Maybe take to local audio place to get tuned correctly. Then wait until I can do it up right. Looks like I bought the wrong amps for what I wanted to do this time. Another lesson learned.
