Looking to see what you guys are getting to fit in the Rushmore RG fairings. And besides shaving off the tabs on the headlights, what other mods did you have to do to get them to fit.
I've been searching this myself as I don't want to put anything in the bags When I had my 09 Streetglide, I had 2 amps and everything else except speakers under the fairing. Now, no space. I have read of guys removing the pods but I thought these were structural/support for the inner fairing so I haven't done it.
Right now I have a 250.2 under the radio, an 800.4 on the headlight, and another 250.2 on a 45* between the radio plugs and outer fairing. Also a psm between the pod and 800.4. Im adding a dsi and another ampnor two this week. I do have lexs rack though
I gave you this info on the PM but I will post it here too for all to see.
I have the MMats MD4110 on top of the headlight with the tabs cut. I also have the Sony radio and I am pretty sure I could fit something small like the NVX or SD 250 on top of the MMats.
I also have a NVX in my wifes RG on top of the headlight without having to cut the tabs. It is mounted in a left/right position just like my MMats. I am pretty sure I could fit two of the NVX on top of the headlight in a for/aft direction.
This is the Lex Rivera amp mount with a SD 1200. I installed one with a DSR on top of the amp. There was room for an amp on top of the headlamp. I believe you can also put a small amp or two in the cubbies.
right on top is an easy fit, I also think the space right behind the light and under the stock HU it pretty big, some kind of amp tray( i made one then didn't use it as this is a lot more accessible) there would hold a few more components pretty easily. I cut the 2 tabs off and trimmed down the angled headlight mounting tabs so they were level, I also swapped out the headlight allen head mounting bolts for button heads, that got me a little more space front to back.
