Speaker Connectors
Old 07-22-2019, 06:50 AM
GunslingersNation1's Avatar
GunslingersNation1
GunslingersNation1 is offline
Default Speaker Connectors
So I just installed the Pioneer TSM 800s and they sound good. The problem is the flimsy Male spade connectors the use. I can't seem to keep the females connected. Does anyone have recommendations on how to correct this?
Old 07-22-2019, 06:53 AM
InthewindMN's Avatar
InthewindMN
InthewindMN is offline
Pinch the females with a pliers to tighten them up a little.
GunslingersNation1 (07-22-2019)
Old 07-22-2019, 07:25 AM
Weeboy1's Avatar
Weeboy1
Weeboy1 is offline
no pun intended?......
Old 07-22-2019, 11:13 AM
GunslingersNation1
How do banana plugs work on the tab style speakers?
Old 07-22-2019, 11:27 AM
marshallb's Avatar
marshallb
marshallb is offline
That's not what they are for really.
If you wanted you could solder a short piece of speaker wire to the pioneer tabs then use the nicer male/female connectors between amp and speaker.
Old 07-22-2019, 11:53 AM
FrenchieM's Avatar
FrenchieM
FrenchieM is offline
Your over thinking this again, do as inthewindmn suggested and problem solved. Not all spades
are created equal. Sometimes a little adjustment is needed depending on what’s available to you.
Old 07-22-2019, 12:10 PM
GunslingersNation1
You're right. I'll try the pliers. I am a little afraid because these Pioneer tabs brittle compared to higher end brands. If it breaks I'll solder on a piece of wire and do it that way.
Thank boys!
Old 07-22-2019, 12:15 PM
GunslingersNation1
Clearly I misread the dancing banana.
marcodarq
Audio Systems
07-21-2018 02:26 PM
DaddyKnuck
Audio Systems
06-07-2017 10:38 AM
Pegasus44
Audio Systems
06-23-2015 07:01 AM
Overdoo
03-06-2014 10:03 AM
Choppie
Audio Systems
04-02-2013 12:44 AM
Quick Reply: Speaker Connectors
