Hertz Amp
Old Jul 25, 2019 | 07:51 PM
Murder King's Avatar
Murder King
Default Hertz Amp
I have a RKS and after weeks of reading different post on audio setups I have decided to run Hertz MPX 165 in the lowers and MPX 690 in the lids. Now my question is do i just stick with the Hertz setup and get a 4ch amp from them or is there a better amp to go with?
Old Jul 25, 2019 | 07:58 PM
eggwhite93's Avatar
eggwhite93
There are good amps for less money for sure. Also read some of the newer threads about the MMats speakers, specifically the 6x9s.
Old Jul 25, 2019 | 07:59 PM
eggwhite93's Avatar
eggwhite93
Old Jul 25, 2019 | 08:19 PM
Murder King
I'll give them a look. What amps are you referring to? I should also mention I live in Arizona so need something that displaces heat well
Old Jul 25, 2019 | 10:26 PM
eggwhite93's Avatar
eggwhite93
Soundigital 800 or Stinger 700 should work well with the speakers you mentioned or the MMats. The MMats 4110 will do well with the MMats as it puts out a bit less power and their speakers are rated a bit lower for RMS power than the Hertz.
