2019 fltrxs
Old Jul 27, 2019 | 12:51 PM
Chad Lewis's Avatar
Chad Lewis
3rd Gear
Default 2019 fltrxs
I have bag speakers, and I just added lowers with pod speakers. Havnt hooked anything up yet. Do I need an amp. Trying to keep everything harley till warranty is up. I'm pretty sure it doesn't have an amp yet., other question is. Will a cvo model amp hold up to six speakers?
Old Jul 27, 2019 | 01:37 PM
marcodarq's Avatar
marcodarq
yes you need an amp, you might need 2. don't waste your time with HD audio equipment. don't worry about your warranty, as long as you make up connectors that match up to the factory harness, you can remove any equipment you install and return the bike to a stock condition if you need warranty work done. some time with the search function here will answer lots of questions that you will have.
m
