Increased distortion ?
Old Aug 6, 2019 | 07:05 PM
madhunter60's Avatar
madhunter60
Default Increased distortion ?
Resently added a DD dsi-2 to my system, before adding I could go to 48 out of 50 on radio before reading distortion on my dd-1, now after adding dsi-2 I can only go to 39 of 50 on the radio before the dd-1 reads distortion why would that be?
Old Aug 6, 2019 | 09:26 PM
Tailwind's Avatar
Tailwind
I just participated in that audio webinar and am gonna guess that this is all about the input volts going into that amp and how the DSI-2 is impacting them. I just switched from the ARC to the DSI to get a couple more channels and my DD1 tradings were an entirely different animal.
T.
Old Aug 7, 2019 | 06:24 AM
madhunter60
Thanks T. I was thinking along those lines but having a hard time wrapping my head around it. Maybe the dsi messing with the preout volts from the radio before sending it on to the amp.
Old Aug 7, 2019 | 06:47 AM
Tailwind's Avatar
Tailwind
Let me know what u find as u tinker with the DSI. I only have about 10 mins of screen time on it but did not see where input volts could be altered other than via a larger scope on the mixer page. The ARC allowed me to select a desired pre-out voltage number.
Just so my cave man brain is understanding ur scenario, with all the amp gains down, 1000hz test tone, DSI-2 all set a zero, ur HU shows dirty on the DD1 at low 30s vs 40?
T
Old Aug 7, 2019 | 07:29 AM
Juice's Avatar
Juice
T.
This would be my guess too.
Juice
Old Aug 7, 2019 | 07:37 AM
InthewindMN's Avatar
InthewindMN
Are you reading that distortion before or after the amp?
Old Aug 7, 2019 | 07:46 AM
IIBADII's Avatar
IIBADII
You are going to have to redo our gains. That dsi-2 outputs an additional 5 volts(I think) to your amp. What I do is set the master db on the dsi-2 to -5 and go from there. On my other channels I have some turned down because a touch of the gain **** sky rockets the voltage on the amp.
Old Aug 7, 2019 | 01:56 PM
madhunter60
Sony radio all zeroed out flat, dsi all flat except for crossovers are set, reading is from rca plugged into the output from dsi with 1000 hz tone rca plugged into dd1, shows starting to distort at 39, when directly plugged into rca fro radio shows no distortion till 49 on scale of 50. This was with mater volume slide at -6db
Old Aug 7, 2019 | 02:29 PM
AlexHz's Avatar
AlexHz
T.
Yesssssssss!!!!!!
Through the master output on DSI-2 you can manage the output voltage from the DSP. Worse case measure the output so you know how high or low you want to set it at so you can best set your gains.
Wheatfield-ez
Audio Systems
Oct 29, 2014 03:26 PM
jamess71
Audio Systems
Jun 30, 2014 09:39 AM
just plain john
Audio Systems
Apr 20, 2013 02:43 AM
3itodd
Jan 5, 2009 10:11 PM
