Blowing speakers.
Old Aug 9, 2019 | 12:13 PM
Dyna88's Avatar
Dyna88
Default Blowing speakers.
Hi guys. Budget setup. 19 street glide special. Stock radio, boom speakers in fairing, Ken wood speakers in lowers, pn4.1000 amp setting is hpf, BT355. I changed some setting in my apple phone for the music app to see if that would help with a bunch of my songs playing lower sound then other songs. It did help but it also would cut my volume off on the songs that played loud, all 4 speakers would cut out. Not sure if the amp was going into protect mode. I would turn volume down and sound came back on. Now I have blown 1 Ken wood speaker and 1 Harley boom speaker. Do I need to reset amp after making change to music settings in phone? Thanks for any advice.
Old Aug 9, 2019 | 12:27 PM
cshocker's Avatar
cshocker
That amp is way too much for those boom speakers. Surprised they lasted at all. Where are your gains set at on your amp? What's your x-over set at?
You might as well start shopping for 4 new speakers (not boom or kenwood).
Old Aug 9, 2019 | 01:14 PM
SBates08's Avatar
SBates08
And do not use your phone as an EQ!!!
Old Aug 9, 2019 | 04:03 PM
travelingypsye's Avatar
travelingypsye
First the boom speakers in the fairing won’t handle the power coming from that amp. They are causing the amp to go into protection mode and shutting down at any volume. Second if those kenwood speakers blew then they weren’t meant to be there either. Spend a bit more $$ so you don’t have too in the future like you are now. $200 will get you a set of Mmats pa601cx for the fairing and $150 will get you a set of hertz sv165 for the lowers and your setup will not only last but will rock as well
Old Aug 9, 2019 | 04:38 PM
Dazoc's Avatar
Dazoc
Where do you find hertz sv 165’s for $150. I’m shopping for a set right now and have only seenas low as $230.
Old Aug 9, 2019 | 06:23 PM
Dyna88's Avatar
Dyna88
Thanks guys. I figured out that my phone Bluetooth was cutting out randomly not the amp. I have my gains set at 11 o’clock. I set the music EQ to flat, volume limit off and sound check off. The kenwoods were free and the booms in there. I have some Rockville’s I will throw in there while I save some cash up for new speakers. In sturgis right now so have to deal with for a bit. Should I leave my bt355 at default since the amp has gains and crossovers?
Old Aug 9, 2019 | 06:50 PM
cpbedor's Avatar
cpbedor
Don't mess with the BT355 settings, you're asking for more problems than it's worth
Old Aug 10, 2019 | 07:28 AM
FrenchieM's Avatar
FrenchieM
Agree with this as well. Too many people trying to use this as a DSP which it’s not.
Old Aug 10, 2019 | 08:29 AM
Sorce's Avatar
Sorce
Your amp has line level inputs so you don't even need the BT355.
Sorce
Old Aug 10, 2019 | 08:54 AM
Fireball Jack's Avatar
Fireball Jack
Sorce
What about the crazy EQ curve. I thought that was what the BT LL were for.
