daisy chaining amp
Old Sep 20, 2019 | 03:12 PM
converted1's Avatar
converted1
Default daisy chaining amp
Good day vv1,
I want to run a jl 280/4 amp bridged to a set of hertz 6.5
I currently have a jl 600/6 powering everything else
Do I need to run all 4 RCA inputs or can I just run 2 ,to run the 280/4 in bridge mode
Thanks in advance for your input
Old Sep 20, 2019 | 03:56 PM
InthewindMN's Avatar
InthewindMN
2 with Y splitters
Old Sep 20, 2019 | 04:48 PM
converted1's Avatar
converted1
To see if I'm following correctly
Of the 4 inputs on the 280/4 I will split to just 2 of those
And if so which 2
Old Sep 20, 2019 | 04:54 PM
travelingypsye's Avatar
travelingypsye
You can run the left channel to to the left front input and run the right channel to the left rear channel input and put the amp in 4 channel input. No need for splitters. Run the outputs channel 1-left + channel 2 rt - and the rears channel 3 left+ and channel 4 right -.
Old Sep 20, 2019 | 06:36 PM
converted1's Avatar
converted1
Thanks for the insight, currently en route from buffalo, will try in the morning
Old Sep 20, 2019 | 10:52 PM
InthewindMN
Have you tried this wiring configuration? Seems like you would only feed half of the input rails. That option isn’t listed in the manual.
https://cdn.shptrn.com/media/mfg/901...pdf?1467235489
Old Sep 21, 2019 | 06:32 AM
USAproud's Avatar
USAproud
JL recommends using all inputs when bridging speakers from there amp. I personally would use y splitters to all channel inputs. Left split to front channels and right split to rear channels
Old Sep 21, 2019 | 06:42 AM
travelingypsye
The amp recognizes input from either 1 side or both. I am currantly running a mmats 4110 and a nvx vadm4 bridged and wired as I stated above. after running a vm to the output side I found no difference in output from 1 or 2 input signals. By all means if jl recommends using a y splitter then do it. I could be wrong as I am a lot.
Old Sep 21, 2019 | 07:54 AM
converted1's Avatar
converted1
That wiring diagram makes it as plain as day,I even understand it
thanks ev1
cfave
Audio Systems
Mar 1, 2018 01:06 PM
rs03371
Audio Systems
Jan 30, 2014 07:36 PM
THABULL
Southeast
Jul 6, 2011 11:36 AM
Whiskers
Jan 22, 2009 10:12 PM
roscoe46
Dec 21, 2007 07:46 AM
