Any 2ch 1ohm stable amp recommendations please...
Old Jan 29, 2014 | 07:15 PM
rs03371's Avatar
rs03371
Default Any 2ch 1ohm stable amp recommendations please...
I have a dual coil 6" sub that i want to play around with that's rated at 1.2 ohms. Are there any available amps that will drive this sub? thanks for the input guys...
Attached Thumbnails Any 2ch 1ohm stable amp recommendations please...-tmp_20140129_172159-1968790106.jpg
Old Jan 29, 2014 | 07:18 PM
Pioneer74's Avatar
Pioneer74
Why not run the coils in series on a 2 ohm stable amp? By the picture, a pbr300x2 might be a good start.
Old Jan 29, 2014 | 07:41 PM
rs03371's Avatar
rs03371
I currently have a pbr300x2. So instead of running a channel 2 each coil just run a single channel to both? So would that basically put 2.4 ohms to the amp which is within spec?
Old Jan 29, 2014 | 07:45 PM
Pioneer74's Avatar
Pioneer74
That's what I would do. You're going to have problems finding a 1 ohm stable 2 channel amp with that low of wattage. Unless you find the Sony branded amp that was installed in whatever Ford car that speaker came out of.
Just make sure you run the coils in series and not parallel.
Old Jan 29, 2014 | 08:07 PM
rs03371's Avatar
rs03371
Thanks!
Old Jan 30, 2014 | 06:16 AM
UltraNutZ's Avatar
UltraNutZ
I would have to ask why?
1.) paper cone
2.) rated at 40w
3.) bass is pretty much useless on a moving bike
Old Jan 30, 2014 | 10:39 AM
GLACIERPEARL's Avatar
GLACIERPEARL
I can see wanting bass,..........but that boat anchor is a waste of time.....
If you're looking for bass, there are options,.............just not that one.
Old Jan 30, 2014 | 07:36 PM
rs03371's Avatar
rs03371
I know I know, it is a pos. It's just an old speaker i found in the garage and thought i'd play around with it.....
Jamestheron08
Audio Systems
Dec 11, 2016 04:05 PM
Bunker
Audio Systems
24
Jun 13, 2016 09:39 PM
pktrusty
Audio Systems
Jun 9, 2016 10:51 AM
Angelsbass
Audio Systems
45
Mar 31, 2016 10:46 AM
912garyb
Oct 10, 2012 08:55 PM
