Is adding a dsp worth it?
Old Oct 1, 2019 | 03:03 PM
c_mancuyas8's Avatar
c_mancuyas8
Default Is adding a dsp worth it?
I've been reading a bit about using a dsp and the benefits but I'm not sure that I'll be able to use it to the full extent with my setup. Pretty much dont want to spend the money and time tuning if it's not going to make a big difference. Thanks in advance for any input!
Head unit
KMR-D772BT
Fairing
Dbdrive euphoria components
Dd vob3 horns
Diamond micro v2 wired high level
Bags
Prv 10mb800ft-1 in each
CV b54 bridged, low level "through" frequency from su bout
Old Oct 1, 2019 | 05:42 PM
Defiasco13's Avatar
Defiasco13
I would say it depends. I’m a noob when it comes to this sled audio, but not audio in general. It depends firstly if you feel like your setup is close to what you want, but needs some tweaks to make it better. It also depends on your budget. $200-$300 for a dsp might be a deal breaker. For me I’m only running fairing speakers, but bought the dd dsi2 knowing I would add more speakers later. I ended up being glad I bought it right now as the small tweaks to the fairing made the money worth spending.
What do you feel like your setup is lacking?
Old Oct 1, 2019 | 05:58 PM
c_mancuyas8
It's not necessarily I think it's lacking. I've entered a couple audio competitions and just always looking on a way to improve. I have lowers and thought about adding another pair of 6.5s.
Old Oct 1, 2019 | 06:02 PM
marcodarq's Avatar
marcodarq
The short answer for your set up yes. You should have one.
M
Old Oct 1, 2019 | 06:06 PM
c_mancuyas8
M
I'm guessing you've used one or are using one. Which have you tried and like best?
Old Oct 1, 2019 | 06:43 PM
marcodarq's Avatar
marcodarq
I have used the ARC PSM, the RF DSR1, and the DD Dsi2. The DD unig is the one I like best and what I run in my bike.
M
Old Oct 1, 2019 | 07:22 PM
c_mancuyas8
Awesome thanks for the info. What all do you run off of it?
Old Oct 1, 2019 | 08:03 PM
madhunter60's Avatar
madhunter60
I bought the DD dsi-2 and it made a world of difference, looking at your setup that b54 amp does not have near enough wattage to push those 10's
Old Oct 1, 2019 | 09:07 PM
marcodarq's Avatar
marcodarq
to answer the op's question to me,
Kenwood 998 head unit,,,,bluetooth from phone or New Sony Walkman
2 PRV 6MR500 NDY 4's in the faring
same in lower farings
2 DD B3 horns in grills in fairing
2 Mmats PA 60.44cx in tp pods
2 PRV 10MB1000's in bags
SD Evo800.4 for PRV's in front and Mmats in tp pods
SD Nano250.2 for horns
SD Evo2000.1 for bags,,,,,,also 2 supplemental batteries, one in each bag, my bike is old and doesn't have as good a charging system as the newer bikes
all run through the DD Dsi2, installed and tuned by me.
Old Oct 2, 2019 | 07:29 AM
c_mancuyas8
You have the amps and dsp in your tp? I don't have one. I'm guessing you are a fan of the as amps how you like 2000.1?
