Is adding a dsp worth it?
Old Oct 2, 2019 | 07:43 AM
c_mancuyas8's Avatar
c_mancuyas8
I had that b54 on 2 crescendo 8s before I got my stretched bags. I've been looking at something with more power
Old Oct 2, 2019 | 08:50 AM
Juice's Avatar
Juice
All the speakers you have need to be band passed (other than the horns). The have a specific place (set of Fz's where they like to play. If your head unit can not provide that, then yes you need a DSP.
Juice
Old Oct 2, 2019 | 10:10 AM
c_mancuyas8
Juice
I believe I set that when I first did the fairing speakers and head unit but I will check again. The components are on dedicated crossovers that came with them.
Old Oct 2, 2019 | 10:16 AM
c_mancuyas8
I think they're new but does anyone have any opinions on prvs A1MH PRO 1Ω amp? I believe this will be a good option to run the 10s as they're 8ohm
Old Oct 2, 2019 | 10:17 AM
Juice's Avatar
Juice
Passive crossovers take away some of the watts you are sending those speakers. So yes a dsp would help and allow you to control the cross over points. The 10's in you bags should be band passed.
Juice
Old Oct 2, 2019 | 01:37 PM
marcodarq's Avatar
marcodarq
i have 2 amps under the faring, the nano and the evo 800, the evo2000 and the dsp are in the tp. there is room that i could mount them in the bags, but i've tried so much stuff through the course that the tp was the easiest to start with.the 2000 is a beast and sounds great, but not what everyone needs, i'm trying to hear some low end while riding at speed and i've found that that requires power.
i am researching the new MMats PA1010 speakers which should take less power to work out well, i've blown one pair up, but i think it was from too much power, when cash allows, i'm gonna get another set and try powering them with the 300 watts they are rated for, i should be able to get that out of a much smaller amp, bridged, either the MD4110 or SDEvo 800, we'll see when i get some more cash, got the amps, but need to get new speakers.
m
Harley SSG
Audio Systems
16
Mar 28, 2019 04:35 PM
ssmorga78
Audio Systems
Oct 14, 2018 05:03 AM
Harley_Newb419
Audio Systems
11
Apr 4, 2017 01:57 AM
Harley_Newb419
Audio Systems
30
Feb 25, 2017 12:33 PM
RDC434
Audio Systems
Aug 2, 2015 10:48 AM
