12V source in fairing
Old Oct 31, 2019 | 10:48 AM
steelpony16's Avatar
steelpony16
Default 12V source in fairing
Hey Guru's
Wondering if there is a 12V Source in the fairing to put on the Amp REM so that when I turn off the radio the Amp will turn off.
I have a 2018 Streetglide,
Thanks
Old Oct 31, 2019 | 10:55 AM
TriGeezer's Avatar
TriGeezer
As long as you don’t overload it. Beside the headlight is unconnected power and ground for European lighting requirements. This is switched with the ignition. I’ve used it for connecting various accessories.
Old Oct 31, 2019 | 11:08 AM
mikes300's Avatar
mikes300
yes, i believe it's a small blue or purple that's the signal wire? I know where it is on the RG but not the SG. Biketronics actually makes a plug and play pigtail for it
Old Oct 31, 2019 | 11:22 AM
Juice's Avatar
Juice
On the brake side there is a 2 wire pigtail the purple wire is the hot and used for switched accessories. Or you can use the cigarette lighter lead too!
Juice
Old Oct 31, 2019 | 11:30 AM
SBates08's Avatar
SBates08
There is no 12v source available that turns off when you shut off the HU. You will have to install a manual switch to turn power on and off.
Old Oct 31, 2019 | 11:59 AM
steelpony16
Thanks SBates08, you were right. Never hurts to ask.
I see like 2 big unused plugs that I think are connected to the HU was wondering if there is a 12V source in 1 of them that switches on/off with the radio.
No U Glider
Audio Systems
Nov 13, 2016 12:11 PM
ratsnest
2014-2024 Touring Models
Aug 25, 2016 06:55 PM
jmelcher
Jun 5, 2013 09:44 PM
vhmike73
Audio Systems
Feb 23, 2013 09:39 AM
ddwyer
Apr 8, 2009 01:49 PM
