Harman Kardon Radio Update for 2013 and older models
Step 1. Visit the HD website, click on PDF instruction, and follow the instructions to determine if you even need to update. If you need to update, follow the instructions on downloading the software update. The webiste is:
https://www.harley-davidson.com/us/e...an-kardon.html
Step 2. Unzip or move the two update files to your desktop.
Step 3. Download Nero 9. This is critical, as most riders (including me) tried to use Windows or other software to burn their update CD and failed. Nero 9 is free here:
https://www.softpedia.com/get/CD-DVD...ero-Free.shtml
Step 4. Open Nero 9 and select the "Add" button and select the two files from your desktop. Click the hammer button and select "minimum" under burn speed setting. Check the box to verify the data after the burn. Click "Burn."
Step 5. Follow the directions on the HD website noted above to use the disk you just created. Be patient while the radio updates...it takes a while and there are times you'll think it's stuck. It's not...it's just a slow process.
Good luck!
Brian
