Leave RCA cables?
Old Nov 4, 2019 | 10:30 AM
jory434's Avatar
jory434
Default Leave RCA cables?
Doing a little changing of my setup. Im going from a Stinger 700/4 running 2 PRV's and 2 horns in the fairing to a Stinger 700/4 running just two 601 CX's in the fairing. So using 2 channels on the amp instead of all 4. I might do lower fairing speaks later, but no plans as of now..
My question is- Any issue leaving the rca cables all plugged into even though I wont be using the rear channels on the amp? I terminated the speaker wires Im not using and taped them up.
Old Nov 5, 2019 | 11:04 AM
marshallb's Avatar
marshallb
Stock HU?
Old Nov 5, 2019 | 12:09 PM
jory434's Avatar
jory434
No sir Sony MEX70. I installed last night and left RCA's hooked up to amp. Still in 4 channel mode, and no problems.
Old Nov 5, 2019 | 12:13 PM
marshallb's Avatar
marshallb
As long as all four are full range signal it should be fine. I know that HU has built in crossovers. It also has T/A so check that. Basically make sure that front and rear channels have the same settings.
pglider
Audio Systems
Sep 4, 2017 01:26 PM
AdmiralAaron
Audio Systems
21
Jul 28, 2016 07:23 AM
ckef_koran
Audio Systems
Nov 9, 2013 07:23 AM
Texas Rapier
Aug 27, 2010 01:06 PM
dredy2g
Feb 25, 2009 10:50 PM
