Audio Help
Old Nov 7, 2019 | 06:03 PM
Jbower83's Avatar
Jbower83
Stage III
Default Audio Help
Hello, new to the forum and new to the motorcycle audio world. My current set up is Hertz 165.3 Millie pros in the fairing, and Hertz 690.3 Millie pros in the lids powered by a diamond audio 84U. My question is right now I have each speaker running to its own channel at 90watts per channel. Would I be better off running these speakers parallel and just run 2 channels? Also I live in Harrisburg PA if anyone has a recommendation for an audio shop around my area they could recommend. Thanks for all the help.
Old Nov 7, 2019 | 10:20 PM
Dsm Limited's Avatar
Dsm Limited
Your speakers are 4ohm, running parallel creates a 2 ohm load. Your amp bridged is not 2ohm stable. That amp bridged creates 275w at a 4ohm load only. No bueno on that setup.
You are going to want a 4 channel amp that creates 150+ watts at 4ohm.
Old Nov 8, 2019 | 06:19 AM
Outkast6991's Avatar
Outkast6991
hey man. Welcome to the audio forum. I'm down in Lancaster. Hit me up if you wanna hear some nice bikes. There's a couple nice ones running around here. As said above that amp probably isn't what you want/need with your current plan
Old Nov 8, 2019 | 11:28 AM
Jbower83's Avatar
Jbower83
Stage III
Outkast6991 what’s the name of your shop or location so I can look you guys up. I’m looking to expand my audio over the winter
Old Nov 8, 2019 | 05:20 PM
Outkast6991
no shop or business here man.i just do it as a hobby out of my house. I have a few bikes around usually and if not I can get some for you to listen too before you make any choices
ColoradoLG
Audio Systems
Jun 4, 2018 01:02 AM
Terminator69
2014-2024 Touring Models
May 23, 2015 07:15 AM
dirtydawg1
Audio Systems
50
Dec 20, 2014 10:06 PM
pit1600
Feb 26, 2012 07:25 AM
Pc PaiN
Sep 21, 2011 12:20 PM
