Speaker upgrade
Old Dec 15, 2019 | 02:26 PM
Kent R's Avatar
Kent R
2nd Gear
Default Speaker upgrade
I have a 2010 FLHTCU with a Harman-Kardin head unit (am/fm,cd,cb). The speakers in the tour pack are 5 1/4 ". I havent checked the speakers in the fairing. I guess what Im actually trying to figure out is can I replace the 2 ohm speakers with 4ohm without it affecting the draw on my battery or anything else for that matter. Or does anyone have any thoughts on bluetooth speakers. Any help will be appreciated. I apologize if my question has already been asked and answered. Its just everytime I start reading these threads I see something else I need to know and before I realize it Im off in another direction. Kinda like when I go riding. Thanx again.
Old Dec 15, 2019 | 02:47 PM
Dsm Limited's Avatar
Dsm Limited
Replacing the stock 2ohm speakers with 4ohm won't do anything to your battery. It will however take away 1/2 your volume from the speakers. I personally recommend putting an amp in place while you're at it.
If that is not something you're interested in doing, my next best recommendation would be to replace with a better 2ohm speaker.
Old Dec 15, 2019 | 03:55 PM
Kent R's Avatar
Kent R
2nd Gear
Default Speaker upgrade.
Thank you for responding. I think I'll go with amp. One with bluetooth or get the bluetooth separately. Thanks again
Old Dec 15, 2019 | 04:42 PM
c_mancuyas8's Avatar
c_mancuyas8
If you can I'd say replace the head unit as well. Changing the head unit add amp and new set of speakers will blow the stock away. You can do it all if you do on your own for a decent set up for about $500
Old Dec 17, 2019 | 07:41 PM
paul1970's Avatar
paul1970
Can also buy a Bluetooth adapter that plugs into your cigarette lighter for under $20
ironfist_001
Audio Systems
Aug 21, 2019 08:44 PM
AlBaron
Audio Systems
11
Jun 23, 2014 09:15 PM
JUVETEACH
Audio Systems
Mar 8, 2013 06:30 AM
Gasitman
Audio Systems
Nov 29, 2012 10:45 PM
blockzilla
Mar 3, 2012 04:49 PM
