Tools for tuning
Old Jan 12, 2020 | 03:02 PM
ScreamingSkulls's Avatar
ScreamingSkulls
oscilloscope, ears and common sense such as not going more than 75-80% higher on the head unit etc etc
Old Mar 8, 2020 | 09:59 AM
123ozzie's Avatar
123ozzie
Bringing this back around. Besides my ears, is there a way/tool to pinpoint where the frequency dial is on an amp? The stinger in particular has two numbers on it, 40 and 400, and is a smooth dial without "clicks". The technical part of my brain wants to know exactly where 80 or 100 hertz is, if possible. Thanks
Old Mar 8, 2020 | 12:19 PM
Stuntmeat's Avatar
Stuntmeat
If I’m not mistaken I think that’s what the SMD crossover calibrater does.
Old Mar 8, 2020 | 12:21 PM
Stuntmeat's Avatar
Stuntmeat
If I’m not mistaken I think that’s what the SMD crossover calibrater does. https://www.sonicelectronix.com/item...e-Designs.html
Old Mar 8, 2020 | 12:42 PM
123ozzie's Avatar
123ozzie
Thanks, I’ll look into it. Anyone on this forum have one and can vouch for it?
Old Mar 8, 2020 | 03:20 PM
marshallb's Avatar
marshallb
Good read...
http://www.soundsolutionsaudio.com/f...llation-tools/
Old Mar 8, 2020 | 04:08 PM
cshocker's Avatar
cshocker
Originally Posted by marshallb
Good article.
I do have one question though. It’s states that if you were to tune at 14.4V for max volume, that if you ran it at 13.3V, that you would be running past distortion max e level. To my non-electrical brain, I thought if you set max at 14.4V, then your actually safer when you’re below those volts.
Old Mar 8, 2020 | 06:29 PM
marshallb's Avatar
marshallb
Originally Posted by cshocker
Good article.
It's an ohms law thing. If you tune to distortion limit then drop the voltage the current goes up, no way around it. Amps have devices in them that have a current threshold that when exceeded will cause distortion in the output.
I don't believe it's a huge factor on a sled. It's just something to be aware of. Now 10K watts on 4 15's I would worry that in a bass race or long demo that my coils will be getting hot as well as my amps.
hardheaded
Dec 27, 2016 08:44 PM
Mchad
Mar 2, 2015 10:03 AM
animalnoll
Jan 31, 2011 11:39 PM
MNPGRider
Nov 2, 2010 04:06 PM
ord sgt
The General Motorcycle Forum
30
May 12, 2009 08:34 AM
