System upgrade
My current setup:
sony xav5000
Kicker 44KSS6504 in the fairing and the lowers
(125 watts at 4 ohms)
2 kicker pxa 300.4, each is bridged to 150x2 with one powering fairing and one powering lowers.
new setup
Sony xav7000 from fathead cycles is on the way
im waiting for delivery on an arc moto600.4 from another member.
here is my dilemma:
I only this morning found out about the Rockford fosgate saddle big retrofit kit. Was first totally against it but after watching the video it seems fairly straightforward and Im thinking Im going to pull the trigger
the issue is how I would power them.
should I use the moto600 to power the front 4, and keep one of the kickers to power the rear? Id like to keep all amplifiers in the fairing so I only need To run speaker wires to the rear.
Could I wire the fairing speakers in parallel to create a 2ohm load, do the same with the lowers, and use two channels for that, and then use the remaining two channels for the 6x9s?
If I went with the two amp setup it is fair to say that 900 watts total would be louder/clearer then 600?
appreciate the feedback guys, Ive been installing tweaking my personal car/motorcycle stereos since I got my first car so Im fairly competent in it. Just want to make sure the Harley is done the best way.
Yesterdays ride straight to the car wash
i have 4 crossovers in there for the components. Been awhile since I had it apart but I think it should be ok. Id rather use both amps so everything is properly powered. I already have distribution blocks for power and ground so Ill just have to remove the old and put in the new.
Hoping this system sounds as good in person as it does Im my head or Ill be very disappointed. 😂😂
Going to be adding an arc moto600.4 to power the 4 6.5s, while keeping one of the kicker amps to power the addition 6x9s in the lids. So 600 watts and 4 6.5s to 900watts +Two 6x9s
sorry if I wasnt clear
an extra 300 watts and 2 more speakers wont be a huge difference? Thats a genuine question. Id expect more bass with the 6x9s and definitely louder no?
