Probably a dumb question but...
Old Mar 31, 2020 | 12:20 PM
rlager's Avatar
rlager
Default Probably a dumb question but...
Hi All,
I have a JL Audio HD900/5 powering two MMats PA801 speakers connected to the subwoofer output of the amp. The subwoofer output is rated at 500 watts and with both Mmats connected to that output - this would mean each speaker is getting roughly 250 watts - is that correct? Also have tweets and a set of Polk Audio MM602's hooked up to the other channels but just want to confirm the wattage that is going to the Mmats in the lids.
As it turns out if this is true that may be a bit much for these speakers...think I just blew one on my way to work this am .
Thanks all!
Old Mar 31, 2020 | 12:45 PM
Fireball Jack's Avatar
Fireball Jack
Did you blow one of the PA801's? What Freq do you have the 801's crossed at?
Old Mar 31, 2020 | 09:45 PM
rlager's Avatar
rlager
I think so but will have to check further. Currently crossed at 80Hz
Old Apr 1, 2020 | 09:25 AM
yooperhog's Avatar
yooperhog
deleted
Old Apr 1, 2020 | 02:52 PM
rlager's Avatar
rlager
Still haven't had time to really test - but realize 80Hz is a little low for these speakers. I've raised it up to 100Hz and lowered my gains a bit. Overall I've been pretty happy with the speakers. Haven't been able to ride much due to various factors but turning them up in the garage is a lot different than turning them up on the road . Am I correct in the assumption that both speakers connected to the sub output would each receive half the output as far as power is concerned? Thanks all - love this Forum although it is expensive at times .
Old Apr 1, 2020 | 06:36 PM
marshallb's Avatar
marshallb
You realize that the sub channel is low pass only right? Not a good scenario for those speakers.
Edit: never mind I see that the filter is able to be disabled, and the response goes up to 10k hz.
Also how are you splitting frequencies?
Old Apr 1, 2020 | 06:52 PM
rlager's Avatar
rlager
Hey! I've disabled the filter on the amp, and am using the DSP (DSR1) as a bandpass to the PA801's in the lids. Hipass - was at 80Hz, raised it to 100Hz, Low Pass 4500Hz.
Old Apr 1, 2020 | 06:56 PM
rlager's Avatar
rlager
not sure if it matters, but tweets are set at 4500Khz to 20,000Khz
Old Apr 1, 2020 | 06:57 PM
rlager's Avatar
rlager
Sorry - 4.5Khz to 20Khz on the tweets
Old Apr 1, 2020 | 07:14 PM
marshallb's Avatar
marshallb
100-4500hz is probably a decent band for the mmats. 4500-20k seems right for the highs.
250W each might be a bit much for the mmats but not ridiculously I wouldn't think.
