Speaker suggestions
Old Apr 10, 2020 | 10:42 AM
Fireball Jack's Avatar
Fireball Jack
Bridged is how I would run it. You will need BT355ll to flatten the EQ curve.
Old Apr 10, 2020 | 02:19 PM
madhunter60's Avatar
madhunter60
are you suggesting 8 ohm speakers wired parallel then bridged, because I think 350 watts to a single 4 ohm mmats is going to be a bit much.
Old Apr 10, 2020 | 03:27 PM
Fireball Jack
No,no,no. I never mentioned parallel . I said bridged because the Mmats can take a bit more power than the stinger will put out in 4 channel mode. Just because the power is available doesnt mean you have to use it all. There is still a gain dial and setting it is the same.
Old Apr 10, 2020 | 07:42 PM
Socalledchad's Avatar
Socalledchad
I put hertz milli pro 165.3 6.5 in my fairing. I'm pretty happy with their sound.
Old Apr 12, 2020 | 05:25 AM
hdrcgb bob's Avatar
hdrcgb bob
Gents ive been on this for 2 years now
Boom is ok to 65mph but I went Focal 4 way amp then added Fosgate marine in 6.5 speakers great up to 80mph but then just loses it.
so if anyone can help I would be grateful
HDRCGB Bob
Old Apr 12, 2020 | 07:35 AM
Fireball Jack
HDRCGB Bob
What is it you need help with?
Old Apr 12, 2020 | 02:38 PM
hdrcgb bob's Avatar
hdrcgb bob
My friend I don't know what speakers to go with, there is so much mis info on here, all I want are 2 speakers to replace my HD boom speakers in my lower panniers, I do mostly highway miles and love to hear music at 80mph + so any advice I will take on board.
Many Thanks Bob
Old Apr 12, 2020 | 02:54 PM
Fireball Jack
Many Thanks Bob
Boom runs 2 ohm so you will be limited if you dont change your amo. Kapps run 2 ohm after that I am not sure.
Old Apr 12, 2020 | 10:57 PM
Tremor58's Avatar
Tremor58
Default Speaker Suggestions
I just recently swapped out my 5.25" OEM speakers, for a set of Polk Audio DB522 DB+, 300 watt (front and rear) I have a 2011 Ultra Limited, I also plan to upgrade the head unit with a Kenwood KMRD772 BT Marine stereo, and a Stinger SPX700X4 amplifier.
the Polk speakers already added tremendous sound quality over the OEM speakers, and I know with the new head unit, and amp pushing the power, it should sound pretty damn good...
Amazon Amazon
Amazon Amazon
Amazon Amazon
Old Apr 13, 2020 | 11:47 AM
harleybob815's Avatar
harleybob815
Just bought mmats. wont see them til the end of april. ill pick things up then I guess
