Help with settings, freq. etc...
Old Apr 27, 2020 | 04:43 PM
Mikes145's Avatar
Mikes145
Default Help with settings, freq. etc...
I have a 2012 Ultra with a Sony Mex-M100BT and a new Stinger SPX700X4. I just got an email that my Mmats PA601cx are being shipped finally. I will put the Mmats in the fairing and for the lowers, I have some Polk Audio MM652 or Infinity Kappa 62.11 speakers that came from my fairing. I won't be using the rear speakers. I'm just confused on the settings of the head unit and amp regarding frequencies etc...Does someone have the settings for these components? Should I set the HPF on the head unit or on the amp, and how in the world can I set it (for example to 100 hz) with that tiny dial? Thanks for the help in advance.
Old Apr 29, 2020 | 07:29 AM
Weeboy1's Avatar
Weeboy1
Set your gains following the “sticky” at the top of the forum.
as far as the filters I’d set the amp to all pass (AP) and adjust via the headunit. Easier to hit the number your looking for.
See what your years like . Start at 100hz can likely go lower especially with the kappas but experiment through the head unit.
only downfall to using head unit may be loss of settings if battery is disconnected or maxi fuse pulled.
wilburbill
Audio Systems
Nov 27, 2019 08:24 AM
Ken Boston
Rockford Fosgate Audio
Jul 30, 2019 08:35 AM
yamiemax
Audio Systems
Mar 31, 2017 09:03 PM
Briguy1
Audio Systems
Aug 1, 2015 02:02 PM
Astro
Jun 21, 2012 04:29 AM
