SD 800.4 Connection Question
Old Apr 28, 2020 | 12:07 PM
scooper321's Avatar
scooper321
Default SD 800.4 Connection Question
So I've been reading up on the Soundigital amps. Specifically the SD 800.4 amp. And I have a couple of questions about the speaker wiring.
The amp has four channels. But each pair of output channels only have 3 connections. So: 1+, 1-/2+, 2- and 3+,3-/4+, 4- That is, the ch 1- shares a physically connection with ch 2+. Likewise, 3- and 4+ share a physical connection. Maybe this is common but I've never seen this before. So looking at the connection diagrams, I'm wondering some things:
In the 2 channel diagram they use ch 1+ and ch 2- for one speaker and 3+ and 4- for the other:
This seems to imply they are bridging the channels to get max power out to the speakers in the two channel configuration. Is that correct? This is how I'd likely use the amp (fairing speakers only) for now, but I don't want to box myself in from being able to add two more speakers down the road. And this is where the shared terminals makes it confusing.
If I expanded to a 4 speaker application (two more in the tour pack), I'd use their 4 channel diagram.
What is going on here with the shared connection? Is this the same as arranging channels 1 and 2 in parallel? Or would they still be considered independent channels when figuring each channel's load impedance? Also, does this sharing of +/- terminals between speakers mean I can't independently control channels 1 and 2 (like for fading)?
Sorry if these are basic questions. I understand audio connecting, but I've never run into shared +/- speaker connections before. So I don't understand the implications or limitations of this on my system.
Old Apr 29, 2020 | 06:29 AM
c_mancuyas8's Avatar
c_mancuyas8
I remember hearing the reasoning for this and Ive forgotten, I remember one thing that they said was it was to save space. I've put in a few of these already bridged or on separate channels I just ferrule the +/- of separate speakers together and it works as it should.
Old Apr 29, 2020 | 07:18 AM
scooper321's Avatar
scooper321
I actually emailed Soundigital to ask them this question. They responded very quickly.
In the two channel configuration this setup iS bridging the amp. So I was on the right track there.
In a 4 channel configuration, it is not parallel or series wiring, they said it is traditional 4 channel wiring. And you were right. SD said that due to the size of the amplifier, there isn't room for a traditional terminal, so they share them externally like this. They said this is how traditional amps are connected internally, they just do it externally. This is interesting. I didn't know that amps were designed this way inside.
Old Apr 29, 2020 | 09:48 AM
c_mancuyas8
Yes I should have specified that what I've been using are the exo x 4 channel amps
Budda109
Audio Systems
45
Sep 3, 2015 08:03 PM
bhibbert80
Audio Systems
Apr 29, 2014 12:08 PM
Scooby1426
May 17, 2013 04:59 PM
circlenine
Aug 2, 2012 09:08 PM
trnewman
May 29, 2012 01:01 PM
