REM (blue pwr) question
Old Apr 29, 2020 | 10:21 AM
flippinhd's Avatar
flippinhd
Default REM (blue pwr) question
I cannot find a solid answer after doing a search. So the HU is running off it's own REM supply. I have a single amp that pulls REM pwr from the DC outlet(cig. Lighter factory outlet) it is okay to run another amp from the same REM pwr that is currently being used for 1 amp?
Thanks
Old Apr 29, 2020 | 10:41 AM
InthewindMN's Avatar
InthewindMN
What bike and hu?
Old Apr 29, 2020 | 10:44 AM
flippinhd's Avatar
flippinhd
Default info
Originally Posted by InthewindMN
What bike and hu?
2016 RG Sony AX 7000
Old Apr 29, 2020 | 11:24 AM
SBates08's Avatar
SBates08
You can run another REM wire from the same source OR you can piggy back from one amp to the next. BUT if the HU has a Remote out wire, that's what I'd be using for my remote. For the simple reason that if you turn the HU off, the amps go off as well. Running the remote from a keyed source will cause the amps to stay on as long as the key is on.
Old Apr 29, 2020 | 11:40 AM
flippinhd's Avatar
flippinhd
Default Got it
Thank you very much, that helps me know I am not going to screw things up.
Houston_t
Audio Systems
Feb 19, 2020 02:43 PM
Chopper Man
Audio Systems
Jan 8, 2020 08:45 PM
JetRanger
Audio Systems
May 27, 2018 01:21 PM
Briguy1
Audio Systems
Nov 13, 2017 06:43 PM
JRandall
May 25, 2013 10:04 PM
