Quick question about setting amp gains
Old Feb 18, 2020 | 06:52 PM
Houston_t's Avatar
Houston_t
Default Quick question about setting amp gains
When using the volt meter method to set amp gains what speaker wattage do you go by ? Min, max, or somewhere in the middle ?
Old Feb 18, 2020 | 07:16 PM
Babyboy's Avatar
Babyboy
Depending on the amp. Some amps have a clean signal over the advertised specs and some amps are way under specs so if you set it via the voltage chart you may have a nice clean signal or an extremely clipped signal.
The best way is to use some sort of way that detects clipping SMD DD1 or an oscilloscope
Old Feb 18, 2020 | 07:19 PM
Tailwind's Avatar
Tailwind
RMS x 150% is a safe ole rule of thumb. I repeat, ole rule of thumb for ur every day average Joe.
T
Old Feb 19, 2020 | 02:43 PM
yooperhog's Avatar
yooperhog
T
But only if your amp delivers that much clean power.
Chopper Man
Audio Systems
Jan 8, 2020 08:45 PM
Briguy1
Audio Systems
Nov 13, 2017 06:43 PM
Stucustom
Audio Systems
Aug 20, 2013 11:01 AM
JRandall
May 25, 2013 10:04 PM
kjkustoms
Audio Systems
Feb 24, 2013 10:28 AM
