SS 4.520 amp question
Old Aug 19, 2013 | 04:16 PM
Stucustom's Avatar
Stucustom
Default SS 4.520 amp question
I have the Sound stream PN4.520 amp with four MM651 Polk speakers. What should I have the amp settings on; LP, HP, or Full range? Thanks
Old Aug 19, 2013 | 06:30 PM
UltraNutZ's Avatar
UltraNutZ
set it at HP
Old Aug 19, 2013 | 06:55 PM
badazzpred's Avatar
badazzpred
Hey UN with my 7.1's and 6.5 titans, sony deck ,and the SS520 what should my setting be at just curious?
Old Aug 19, 2013 | 06:57 PM
UltraNutZ's Avatar
UltraNutZ
got a DMM?
Old Aug 19, 2013 | 07:00 PM
badazzpred's Avatar
badazzpred
Originally Posted by UltraNutZ
got a DMM?
If your referring to a digital multi meter yes I have one
Old Aug 19, 2013 | 07:01 PM
UltraNutZ's Avatar
UltraNutZ
should be roughly 28.8v AC on front and rear. That is clipping voltage. So back it down to 27vac for safe measure and set your crossover to FP first. If after you get your gains set and you listen to the music at a moderate volume find too much bass (lower end) then flip the FP switch to HP...
also remember on these sony headunits.. with all EQ settings flat, the gains turned down all the way on the amp. if you don't hear distortion when you hit your max volume which is 50 then back it down to 36 and set your gains from there.
Old Aug 19, 2013 | 07:21 PM
badazzpred's Avatar
badazzpred
should be roughly 32.2v AC on front and rear. That is clipping voltage. So back it down to 31vac for safe measure and set your crossover to FP first. If after you get your gains set and you listen to the music at a moderate volume find too much bass (lower end) then flip the FP switch to HP...
Not to sound stupid but how do I go about testing the front and rear properly? setting on the meter? test which front and rear? ground? bike on auxillary or running? I will say this I rode all day yesterday and with just the 7.1's running It cranks!! right now the way I have it set Is I think I had my HU set at flat, gains on amp down all the way, I turned my volume up to 35 and then set my front gain to about 10 or 11 O'clock on the full pass setting It cranks but while riding I really havent turned it up past 35 dont want to risk blowing the speakers. even though It cranks I still think it could use more low end bass but Im also not using any poly fill at the moment either so I dont know if that may help with the low end?
Old Aug 19, 2013 | 07:30 PM
UltraNutZ's Avatar
UltraNutZ
set your meter to auto AC volts. Disconnect your speakers from your amp completely to do this.
plug in the 1000hz test tone as the sticky suggests eithe rvia CD or iPod or thumbdrive so you have a constant voltage output. Setting amp gains with a DMM and using music is a futile effort and will never be right, needs to be a known frequency test tone for the range your speakers are capable of handling. 1000hz/1khz is a normal test tone for coaxial speaker setup.
Now as the tone is playing through the system with the volume on the head unit at 36, touch the red lead on the meter to the + on your right front speaker output of amp and the black lead to the - on your right front speaker output of the amp. Now turn your front gain control up until you hit 31v and stop. Now without adjusting anything take your leads and move them over to the left front speaker output of the amp. If you have a different reading than the right I usually split the gain setting difference down the middle and subtract it from the 27v setting. Meaning if you have 27v on the right channel and 27.8 on the right channel, then I'll back down the gains to be 26.6v or close to it.
Old Aug 19, 2013 | 09:16 PM
Stucustom's Avatar
Stucustom
Default Amp
Thanks UN. Last question, not sure if it makes a difference but I am running a Sony deck.
Old Aug 20, 2013 | 10:13 AM
UltraNutZ's Avatar
UltraNutZ
no sir no difference.. just make sure everything on the head unit is set to flat (eq, bass, treble, etc.) otherwise you're wasting your time.
