Soundstream amp x-over question?
Old Feb 24, 2013 | 06:06 AM
kjkustoms's Avatar
kjkustoms
Question Soundstream amp x-over question?
Just finishing up the amp install, going to set the gains, question is: where should I be setting the x-over, the amp has 3 settings, HP80Hz,LP80Hz,or F ? which one ?
Old Feb 24, 2013 | 06:50 AM
Nitro NHRA's Avatar
Nitro NHRA
Read the sticky above HOW TO SET AMP GAINS. Its based on the SS amp
Old Feb 24, 2013 | 07:02 AM
UltraNutZ's Avatar
UltraNutZ
there are those that will disagree with me on this but I get a MUCH fuller sound setting the x-overs at F.
Old Feb 24, 2013 | 07:05 AM
ratdoc's Avatar
ratdoc
Some people recommend using the high pass setting to reduce distortion at extremely high volumes. I tried that but felt I lost too much bass, so I've got mine set on FULL.
Old Feb 24, 2013 | 09:49 AM
2007z71's Avatar
2007z71
I also tried hp and was not impressed with the quality!
Old Feb 24, 2013 | 10:28 AM
floridapoolboy's Avatar
floridapoolboy
Using the HP setting only works with an amp that allows adjustable HP frequencies. The fixed 80hz HP on the Soundstream is a bit too high, blocking too much bass. I wouldn't run in HP unless the frequency can be set at 50hz or lower, stick with full range on the Soundstream.
JetRanger
Jun 1, 2018 05:17 PM
cfave
Audio Systems
Mar 1, 2018 01:06 PM
Briguy1
Audio Systems
Nov 13, 2017 06:43 PM
stevemucha1
2014-2024 Touring Models
Dec 22, 2014 01:41 PM
Stucustom
Audio Systems
Aug 20, 2013 11:01 AM
