Touring stock radio replacement question
Old Apr 29, 2020 | 03:57 PM
Pozzi's Avatar
Pozzi
Stage II
Post Touring stock radio replacement question
Newbie here posting for the 1st time. Could use a little of your help & expertise. Got a 2008 Ultra Classic with a stock HK system. (yea, I know...should just upgrade the whole thing) Washing my bike last year I didn't notice that the CD door was in the open position and, you guess it...water got in it. Everything still functioned fine but the LCD display took a crap. I found a used OEM taken out of a Street Glide (model numbers are exactly the same: H-D P/N 76160-06) Got it installed and there is one issue. In scrolling thru the settings, there isn't an option to adjust the fade between the F & R speakers. It recognizes the rear speakers & they work fine, but with the original radio there was an option to adjust the fade that doesn't show up on the display on the replacement radio which obviously wasn't needed for the Street Glide. What am I missing here? Thanks in advance!
Old Apr 29, 2020 | 04:38 PM
Road Gliderman's Avatar
Road Gliderman
You have to get it flashed by the dealer, set up right now for 2 speakers on Street Glide. Also you may want to go to the new member section and introduce yourself with a pic of your bike.
Old Apr 29, 2020 | 04:44 PM
Pozzi's Avatar
Pozzi
Stage II
Thanks for your response Road Gliderman. Makes sense. I did find some other threads about a flash needing to be done at the dealer. Where exactly is the new member section?
soxfan1965
Audio Systems
Jul 21, 2015 09:18 AM
Cabocarl
Nov 15, 2010 07:17 AM
PHREDD71
May 15, 2009 10:20 AM
bucket13
Nov 6, 2008 09:06 AM
Road Head
Apr 30, 2008 01:56 PM
