Remote wire install
Old May 4, 2020 | 07:58 AM
Phobostx's Avatar
Phobostx
Default Remote wire install
Looking for advice for the best method for installing the "remote on" wire into the MMATS MD4110 amp. I have the switched power source already but the remote on wire is quite small (18 gauge) and the pinch terminal on the amp is quite large. I was considering just adding a ring terminal to the 18 gauge wire and just tightening down the set screw as much as possible but I'm not sure how good of a connection that will make. anyone share some insight as to how they connected theirs?
Old May 4, 2020 | 10:03 AM
boosted20v's Avatar
boosted20v
Stick it in and tighten it down, it'll be fine.
Old May 4, 2020 | 11:27 AM
Biggzed's Avatar
Biggzed
If you're really worried about it you can strip off about 2-3 times what you normally would. Then fold the wire over itself a couple of times. Then twist it and stick it in the amp.
Zach
Old May 4, 2020 | 01:06 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
I think I did sort of what Zed said but I wrapped the wire over a small section of the unstripped wire and then stuck it in there to fatten it up.
After I changed amps though I got a wire ferrule kit and crimpers to give it a real solid purchase. I think it was something like this bugger here:
1200pcs Wire Terminal Connector Set w Ferrule Crimper Crimping Plier Tool Kit
Old May 4, 2020 | 06:23 PM
spidermo's Avatar
spidermo
I went with the Ferrule ends as well. Makes for a more professional look and solid connection point.
Old May 5, 2020 | 09:32 AM
Hoyt 1911A1
One thing I forgot about those ferrules is they have a little gauntlet on them that keeps stray wire strands from touching other wires in a connector block. When you have speaker terminals that are real close together it's a nice bit of added insulation against possible shorts.
FREAKUMCNJ
Audio Systems
Aug 9, 2016 10:10 AM
TcHunter
Audio Systems
Jun 10, 2016 02:16 PM
Cheesehead_13
Audio Systems
11
Jun 7, 2016 12:56 PM
Jaxx
Audio Systems
May 18, 2016 11:25 PM
powderhound77
Audio Systems
Jun 26, 2014 09:35 PM
