Difference between 8 and 10 guage wire
Old Jun 25, 2014 | 04:59 PM
powderhound77's Avatar
powderhound77
2nd Gear
Default Difference between 8 and 10 guage wire
I am installing a SoundStream Pn4.520D 4 channel amp. The manufacturer recommended wire for power and ground is 10 ga. I have been reading on this forum that many have used 8ga. How much difference is there between the two? Is it worth going with the 8 guage wire? I will be powdering two 6.5 Polk db 651 and two Polk 5.25 speakers.
Thank you all.
Old Jun 25, 2014 | 05:51 PM
AAWAV's Avatar
AAWAV
10 will work just fine... It is a Class D amp, not sucking AMPS like class A/B
I got MM651 and 6x9 Pioneers running and had 10G in bike already due to RF300x2.
EDIT: ensure you use good quality wire, some cheapo stuff does not turn out to be the Gauge they say it is.
I used the RF 10G set. good quality...
Old Jun 25, 2014 | 06:14 PM
rwb1's Avatar
rwb1
I bought 2 10 gauge kits for my RFpbr300x2....first was an e-bay cheapo, and the 2nd was a RF 10gauge install kit....difference was night and day. The RF wire was 2x the thickness of the cheap "BOSS AUDIO" kit.
Found it @ new egg for $19...
Old Jun 25, 2014 | 06:31 PM
acchd's Avatar
acchd
You have to consider on bike wire length is much shorter vs car install 10 gauge should be fine.
Old Jun 25, 2014 | 09:42 PM
1HD2NV's Avatar
1HD2NV
Noticed on the 2180 I installed tonight that both + & - was only 14 awg. Need to extend the - & will obviously just go 14 but seems smaller than what everyone here is suggesting. Perhaps just amp specific...
Old Jun 26, 2014 | 05:11 PM
jamess71's Avatar
jamess71
I just asked this same question in another thread about 10 minutes ago. Looks like you can get the good RF kit in 8 for about half the price of the 10 awg.
1HD2NV? so how long do the power cables need to be to get from amp under fairing to the battery? I'm assuming you got a kit with a 3 foot piece of gnd cable?
Old Jun 26, 2014 | 06:43 PM
UltraNutZ's Avatar
UltraNutZ
the length from fairing mounted amp to battery routed under tank through the wiring channel is less than 6'. 6' give you plenty of slack for fuse install and routing to + terminal on amp and you'll probably still cut about 6" off of it.
Old Jun 26, 2014 | 09:35 PM
1HD2NV's Avatar
1HD2NV
Agreed. I bought 5' to match the BT supplied + wire & it was plenty long enough.
Wilkesfastjay
Audio Systems
Apr 20, 2019 07:29 AM
FREAKUMCNJ
Audio Systems
Aug 9, 2016 10:10 AM
TcHunter
Audio Systems
Jun 10, 2016 02:16 PM
Jaxx
Audio Systems
May 18, 2016 11:25 PM
Babyboy
Audio Systems
Oct 28, 2015 07:22 PM
