streaming quality
Old May 7, 2020 | 06:33 PM
desperado 66's Avatar
desperado 66
when i use spotify in particular its volume is much lower than my pandora, cd, and fm, I used the built in adjustment on my head unit and its 9 clicks higher than all the others, the add they run constantly says for 20 some dollars a month you get no ads ",better sound" quality etc... just wasnt sure if the freee version is restricted in volume or something?
amazon is one i did not even know about, i will try it tonight thanks,
Old May 7, 2020 | 06:52 PM
decencyxdefied's Avatar
decencyxdefied
I pay 9.99
Old May 7, 2020 | 06:54 PM
mikes300's Avatar
mikes300
Originally Posted by lefty33
Was this with Spotify? If so, would you be able to elaborate as to where to find this setting? I'm using iPhone with paid Spotify.
no it was satellite radio, sirius XM, and yes it was an I phone, look in spotify settings they may have it too.
Old May 8, 2020 | 08:45 AM
lefty33's Avatar
lefty33
Originally Posted by decencyxdefied
Got it...thanks! Mine is currently set on "Automatic (Recommended)". No complaints so far but maybe I'll try "High" to see if it makes a difference.
Old May 8, 2020 | 01:53 PM
mrmagloo's Avatar
mrmagloo
The trick with Spotify is to always select VERY High for Stream and Download for the best quality at all times. Then, turn OFF 'Download using Cellular', so you do not kill your data plan when you are away from Wifi and riding the bike.
Also, open the EQ and make sure it's relatively flat for any output source you are using with it's own SQ adjustments. Then I download everything to my phone's separate 128GB SD card, and when riding the bike, I only play what I have downloaded. Sounds pretty good in most cases.
Old May 8, 2020 | 06:00 PM
desperado 66
I tried amazon today, awesome!! I will give it two thumbs up, much better than the others,I and easier to use as well. thanks guys
billablehours
Audio Systems
Jan 31, 2017 08:00 PM
cvaria
Jan 20, 2017 01:58 PM
JHC210
Audio Systems
Sep 3, 2016 09:53 AM
ARMY Vet
Apr 11, 2008 09:45 PM
