Hey everyone, looking for suggestions for my wifes bike. She just got a 16 street glide and is not happy with the sound, so its time for an upgrade. I have 4 pa speakers on my bike, 2 horns and a dsp. Its been a while since Ive been audio shopping so Im looking for suggestions.
Im looking for a fairing only setup, could be mids and tweets/horns or coax. Im not opposed to running multiple amps or a dsp. For now...I plan on leaving the stock head unit and bt lls. There is no budget for this build, I just want great sound and volume given the fairing only limitation.
I was browsing and came across the exm6n, prv horns and a dsp, but am looking for advice from the experts here. Thanks!
If money was no object I would -
Beyma 6CX200Nd/N Soundigital 1200.4 EVOX - 4 Ω
Your choice of DSP
I like my setup - doesn't cost a lot and it sounds at least twice as good as stock.
Stinger SPX700.4 ($175 on Amazon)
MMATS 601.4CX marine coated ($215/pair)
any amp wiring kit will do with 12ft of 8ga power/ground, 6ft of 16 or 18ga speaker wire, and 60A fuse block ($40?)
Sounds like you already have line levelers
A good 2 speaker only setup that budget isn't limited? I like Hertz ML 1700 or 1650.3. Mix that with a pair of Beyma SQL 60 horns. Not overly loud but good sound quality and punch!
I"m running the 1650.3 off a focal sport amp(and bag speakers) and some of the new DA MO75T slim tweeters in the grills off a soundstream nano amp, it's pretty dam loud and sounds great, and yes with the rears off, he could go different Amp though or the Focal and a DSP
I think he meant hertz ml 1800.3 with beyma sql 60s. Not cheap by any means but superb SQ. That is my currant fairing setup.
