DSP setting
Old Jun 5, 2020 | 09:28 PM
sbeamer's Avatar
sbeamer
Default DSP setting
I have everything installed.
SD 800.4 Evox amp
Faital Pro-coax speakers. Wired parallel and bridged, on the woofers. The tweets are wired on ch. 3 & 4.
DSP is a RF DSR1. It was sent for a 2 speaker only system. BUT, because I am using ch 3 & 4 for the tweets, I had to connect the rear ch connectors from the DSR.
It is wired correctly per Am Hardbags. So what I don't know how to do is, turn on the rear speaker outputs. I can't figure out how to turn them on without having to re-flash the whole program or what ever it's called. I can't even get access to the on/off switches where ever in the hell they are. So far. I am really hating DSP stuff.
Old Jun 6, 2020 | 09:15 PM
sbeamer's Avatar
sbeamer
Day 3. Still can't get the DSR1 to talk to the Perfect tune app. There has to be a simple solution to this, but I can't figure it out.
Suggestions ?
Old Jun 6, 2020 | 09:35 PM
Outkast6991's Avatar
Outkast6991
Suggestions ?
what device are you using to connect to the dsr1 ?
Old Jun 7, 2020 | 07:58 AM
sbeamer's Avatar
sbeamer
I tried to bluetooth, either it doesn't recognize something or other or, can't connect.
I tried to use the desktop link, Maestro, but I can't find a way to download the file onto it.
Old Jun 7, 2020 | 09:12 AM
sbeamer's Avatar
sbeamer
When trying to use the phone, I get; "unable to pair with DSR1" etc. For some reason, I cannot bluetooth the phone. Ready to turn 1 of these 2 things into a frisbe !
Old Jun 7, 2020 | 09:26 AM
Scarydog's Avatar
Scarydog
Did you get the DSR1 ffrom american hardbagger? Did they pre-program it? If so that may be why you can't connect. You'll have to ask them. If it was your own purchase check with Rockford. I've heard that unit gets complicated to use for some or you may have a bad unit.
Old Jun 7, 2020 | 05:41 PM
sbeamer's Avatar
sbeamer
I did buy it from Am. Hardbag. I have the new program from them on my desk top and on the phone. Just can't get the DSR to pair w/phone.
Old Jun 7, 2020 | 07:09 PM
Outkast6991
when you search for it on the app does it show the dsr1 or nothing at all?
Old Jun 7, 2020 | 08:14 PM
sbeamer's Avatar
sbeamer
nothing. It just sits @ home page. I think that's what it is anyway.
Old Jun 7, 2020 | 08:26 PM
Outkast6991
this page is blank when the system is powered up?
