DSP setting
Old Jun 8, 2020 | 07:18 AM
sbeamer's Avatar
sbeamer
Nope. It's the screen where it shows the eq punch, the master volume and I think it's the sub volume ? There are only 3 icons to toggle. Then there is the tune and blue tooth and set up icons on the bottom. I have not seen the device manager yet.
Old Jun 8, 2020 | 07:28 AM
Outkast6991's Avatar
Outkast6991
hit the Bluetooth icon and it should bring you to the screen I showed ya. If the dsr1 is powered it should show in the device manager. Then just tap the listed device and it should pair
Old Jun 8, 2020 | 07:39 AM
Babyboy's Avatar
Babyboy
Make sure the location on the bluetooth device you are trying to use is turned on.
I have found that to be a common problem when trying to connect to the DSR1.
Old Jun 8, 2020 | 08:15 PM
sbeamer's Avatar
sbeamer
When I click the red bluetooth icon, it stays red
Old Jun 8, 2020 | 08:35 PM
Outkast6991
but does it show a dsr1 active in the manager? is it that it just wont connect or is it not there at all?
Old Jun 9, 2020 | 12:30 PM
sbeamer's Avatar
sbeamer
From my limited phone experience, all I know for sure is, the DSR denies the pairing with the phone. Tomorrow I will try an Apple phone.
When I try clicking the red icon, it just says not connected. That's where I end.
Old Jun 9, 2020 | 06:30 PM
2017M8's Avatar
2017M8
SBeamer,,,,I just ran across this link: http://rftech.custhelp.com/app/answe...tion-solutions
Not sure if this will help sir,,,,,Cheers
Old Jun 9, 2020 | 08:20 PM
sbeamer's Avatar
sbeamer
I'll try anything. Although this one looks familiar.
Old Jun 10, 2020 | 10:16 AM
sbeamer's Avatar
sbeamer
SUCCESS !!!
Now that I'm in. I did get the new file from Am. H B loaded into the DSR1. Instantly better sound! And I dont even have the tweets connected.
My Dilemma;
Before I connect the tweets, this is a 4 ohm SD800.4 amp. The woofers are bridged/parallel. the tweets will run on ch 3 & 4. The tweets are 8 ohm. Is this an issue for the amp ? They only require a MAX of 30w. "How do I do this" ?
I don't want to let the factory smoke out of them. Please keep in mind, this is the FIRST time I am attempting this. I can use a multi meter, and I do have the SMD CC1 and distortion detector.
Here are the specs
LF 300w sensitivity 93dB range 90-5000 min X-over freq 1.7 Hz
HF 30w sensitivity 93dB range 1500-18000 min X-over 1.7
Now, how do I get there ?
Old Jun 10, 2020 | 10:22 AM
Outkast6991
Just wire the tweeters on 3/4 normally. Use the dsr1 to set the crossovers and trim them back
