Adding oil
Old Jun 11, 2020 | 07:50 AM
travelingypsye's Avatar
travelingypsye
Originally Posted by CaffeineBuzz
Sorry guys... I’m a frequent visitor to the audio section and accidentally posted here. Thanks for the answers though.
And Strych.... your a good guy...always helpful with knowledgeable advice.
I know you are. That's why the sarcasm.
Old Jun 11, 2020 | 08:35 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Caffeine I'll throw my .02 in about oil since you are here. On my 2010 Ultra with around 44,000 miles on it I have to add less than half a quart of oil between changes. Myself and the previous owner have always run Amsoil synthetic 20W50. I think that's pretty good considering my bike has that problem a lot of 96 inch motors had where the gasket between the case halves pokes out in the bottom and leaks a little oil.
Good luck.
Old Jun 11, 2020 | 09:46 AM
SBates08's Avatar
SBates08
I had a new oil pump put in the bike about 4500 miles ago.
It's due for the 25,000 maintenance and I'm bringing it in on Thursday.
I've had to add 3 quarts of oil during this interim to keep it topped off.
I know I come across as a greenhorn by asking this, but I'm not proud. If you are going to lay into me...just be gentile....I'm fragile.
Am I expecting too much by feeling like a bike should not have to have 3 quarts of oil added to it every 4.5k miles? Maybe this is how v-twin, air cooled engine are?
bike runs fine, great in fact....no smoke or unusual smell in the exhaust
So have you not changed the oil since the pump was put in 13,000 miles ago or am I misinterpreting your post?
Old Jun 11, 2020 | 02:49 PM
CaffeineBuzz's Avatar
CaffeineBuzz
new oil pump went in about 4500 miles ago, when I did my 20k maintenance
Old Jun 11, 2020 | 03:43 PM
travelingypsye
I will tell you that the M-8's can have a sumpting problem that will push the oil into the tranny thru the clutch rod opening. The statement I heard it was do to the smaller (thinner) primary and vacuum causing the oil to cross into the tranny. HD did not do a recall but if the problem occurs, they have a "kit" to repair and will do so even if not under warranty under a service bulletin with the dealers.
Old Jun 12, 2020 | 08:03 AM
CaffeineBuzz
i wanted to come back and mention two things
one....I took the bike in yesterday for the 25k maintenance and the tech said that while it's generally 'accepted' that these may burn up to a quart every 1000-1500 miles, he doesn't think that is acceptable, they are going to rip into it
second point....this is the very first civil discussion about oil I've ever witnessed on HDF.....i've said it before....the audio guys here at HDF are the best of the best here....great guys, super helpful
Old Jun 12, 2020 | 08:14 AM
teedoff65's Avatar
teedoff65
Well coming from hanging out on the M8 forum for a couple years, over there yes....theres SO many posts...post after post after post about oil transfer, sumping and warranties........so there are a lot of the regulars there that were fed up hearing.it lol. I got fed up with the ppl fed up as well.
Old Jun 12, 2020 | 09:24 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Stop back again and let us know what they find. Inquiring minds always like to know the finial outcome.
Old Jun 12, 2020 | 10:07 AM
Juice's Avatar
Juice
@CaffeineBuzz
Kapones tonight?
Juice
Old Jun 12, 2020 | 10:09 AM
Jackie Paper's Avatar
Jackie Paper
Do you add oil often to your radio?
