look under the gasket tape, there are actually 2 sets of holes, for a total of 8 holes used for different set ups. if you cant get anything that lines up there, then yes drill and tap your own.
m
m
OK, so that means drilling holes in the speaker frame, as the mounting holes on the speakers stick out beyond the bracket itself. I was hoping not to do that but whatever.
None of the holes will work. To make it fit I will have to remove the foam gasket and drill really close to the cone of some really expensive speakers.
I make a thin spacer that fit the profile of the Bayma's and screwed that to the BT adapter. I had to offset the speakers a little to get the fairing back on. Tight fit but it worked. I was definitely not comfortable with any modifying of the Beyma's. This was on a 2012 Roadglide.
I agree with you. I'm not going to drill into these things.
I went through the same problem when I bought a set of Beyma's for my 2012 Roadglide Custom.
Nothing I could do to get them to fit so I just sent them back for a refund.
Mike
Mike
I bought them from a forum member who is a dealer. I'm guessing there is no return policy.
drill the BT bracket in order to line up with the speaker, i didn't mean to drill the speaker!!!
hold the speaker in place on the bracket, mark the holes and drill it.
m
m
That's the issue. The bracket is smaller than the speaker. The holes that are available on the speaker are too wide for the bracket.
