I have been through 2 vadm4 amps over the last 4 months, both of which have had one or two channels stop working. I'm having trouble getting this one replaced under warranty, so Im thinking about trying a different amp.
The amp is bridged powering a set of hertz cpx 6x9's in my bags. Anyone have a recommendation on a replacement? Size would would need to be very similar to the vadm4, there is not much space left next to my BT 4250.
Those have a pretty good track record? I just don't want to be replacing amps every 2 months like I have with the vadm4.
Also the sd is rated at 85 W @ 4ohm. Is that going to be enough power for those speakers? Prior to this I had the vadm4 bridged which on paper would be considerably more power.
