Wiring Help
Old Sep 3, 2020 | 07:57 AM
702's Avatar
702
Default Wiring Help
2019 SGS, Boom GTS..
I'm upgrading the Rockford Fosgate System I had installed in Sturgis last year. I put Cerwin Vega ST69CX's in the bags, and installed this Diamond Audio kit in the fairing --- https://www.americanhardbag.com/coll...t-part-14sgpfk
My question is about wiring the crossovers/horns - Currently I have the crossovers coming off the 6.5" speaker connections to crossover to the horns since I only have the one RF amp. Bad idea? Need another amp for the horns? If so, what would you suggest?
Old Sep 3, 2020 | 12:45 PM
Juice's Avatar
Juice
Wiring horns in parallel with woofers is never a great idea. Unless, you are running a passive xover network like a component set of speakers. I would look into a small sd250.2 for your horns. If you want even more control over everything a DSP would be a nice upgrade.
Juice
Old Sep 3, 2020 | 01:19 PM
702's Avatar
702
Juice
Thank you.
StreetGlide 2019
Audio Systems
19
Nov 12, 2019 01:31 PM
DAVENRINO
Audio Systems
Mar 21, 2018 12:31 PM
WallyWhite
Audio Systems
Nov 11, 2015 10:03 AM
roadkingdoc
Audio Systems
May 11, 2014 07:11 AM
heywood727
Apr 4, 2010 09:05 PM
